Have to hold onto paper as it feeds out so as to stop it from hitting paper.
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: Printer will not feed paper
I have this problem only when i try to print from my computer and i have the solution: disconect all usb devices from your . computer except the printer.
SOURCE: LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC.
Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other
debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and
replug and try a test print.
Also make sure that you have waited long enough
for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper
sensor. If this is the case, you will probably have to take the printer in for
servicing..
SOURCE: I have a Lexmark X2690 printer that is 3 months
From Lexmark support:
1. Make sure:
· You use paper designed for inkjet printers.
· If you are using photo, glossy, or heavyweight matte paper, you load it with the glossy or printable side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
· The paper is not used or damaged.
· If you are using specialty paper, you follow the instructions that came with it.
· You do not force paper into the printer.
2. Before loading paper the first time, slide the paper guides out toward the edges of the paper support.
3. Load the paper vertically in the center of the paper support, and adjust the paper guides to rest against the edges of the paper.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
In addition,
Paper jams inside the All-In-One
Step
Action
Press the button to turn off the All-In-One.
Lift the scanner unit.
Snap the scanner support into position to hold up the scanner unit.
Firmly grasp the paper, and gently pull it out.
5
While lifting the scanner unit, press the scanner support back until it slides into the slot, and close the scanner unit.
6
Press the button to reset the All-In-One.
Hope this helps.
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Paper jams
85% of paper jams are caused by worn rollers Chances are, when your tech arrives, he'll tell you that the jams were caused by worn feed rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
MP150 reset:
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
