Question about Dryers
Fisher Paykal dryer DG08,how to clean vent inside machine
    Genius:
  • 1,122 Answers
Use a dryer lint brush(walmart $10) loosen everything then **** out with shop vac do the same thing to the wall vent but also use a leaf blower to clear it all the way out,let me know how you do-mike
Posted on Oct 02, 2008
Fisher Paykel DG08 has too long dry times (hours).
Could be a variety of issues. If it is an older dryer, there could be a buildup of lint inside which prevents efficient heat transfer. It could also be a blockage in the exhaust hose, the area that the lint filter sits in, or the burner nozzle may need to be cleaned or replaced. Do what you are comfortable doing to clear any blockages, but don't experiment where gas is involved...seek a repairman if necessary.
Oct 09, 2014 | Dryers
Dryer moisture sensor not working
coolblueworld.com is fisher paykel wed sight
Mar 07, 2014 | Fisher and Paykel Dryers
Have a dggx2, unit is taking 3 hours to dry clothes. we cleaned dryer vent, did not solve problem. any help thanks. ldchada@comcast.net
noavatar_s.gif seth765
Rank: Guru
Rating: 89%, 593 votes
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Mar 20, 2011 | Fisher and Paykel DG08 Electric Dryer
Clothes not dry
check your dryer venting from the machine to the outside vent,if they are plugged it will not dry properly,then make sure you have good air flow to vent on machine,if not dismantle and clean lint from inside machine,these are inexpensive fixes,then it could be a cycling switch or the humidity sensor bar that needs replace
Jan 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykal washing machine, Mod:GHL10US
if you want to find out for sure post your email here and i will send you the service manual
Jan 15, 2008 | Fisher Paykel EcoSmart GWL15
Dryers Logo
Top Dryers Experts
