I get a ntldr error when trying to run Win XP. I have a dual boot with Vista. I've copied the ntldr and ntdetect.com to the root drive where I've loaded win xp (g:). how can I fix this problem so I can complete installation of Win XP
    Sergeant:
  • 250 Answers
The advice I got was good. Check the easy bits first. Is one of the cables to your Hard Drive disconnected?Second: Use your Windows Installation disc,and go to Recovery Console, or Repair an Installation. When you reach the command prompt, typethe following two commands, pressing ENTER after each one: copy d:\i386\ntldr c:\ copy d:\i386\ntdetect.com c:\ IF you are prompted to overwrite either of these files, press YES. Take out the Windows CD, type EXIT, and then press ENTER TO RESTART YOUR COMPUTER. If this doesn't work for you, get in touch with me again, and I'll give you some more things to try
Posted on Oct 03, 2008
Samsung N150 ntldr is missing, how can i fix that problem
Common Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Corrupt boot sector / master boot record.
  6. Seriously corrupted version of Windows 2000 or Windows XP.
  7. Loose or Faulty IDE/EIDE hard disk drive cable.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Apr 18, 2011 | Samsung N150 (36725723009) Netbook
Tip
How To Repair NTLDR or NTDETECT.COM Not Found
If you get an error that NTLDR is not found during bootup,
If you have FAT32 partitions, it is much simpler than with NTFS.
Just boot with a Win98 floppy and copy the NTLDR or NTDETECT.COM files
from the i386 directory to the root of the C:\ drive.
For NTFS:
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. Enter in the following commands (X: is replaced by the actual drive letter that is assigned to the CD ROM drive.
    COPY X:\i386\NTLDR C\:
    COPY X:\i386\NTDETECT.COM C:\
  6. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Windows XP users
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
Ntldr is missing press clt alt del to restart
The NTLDR and Ntdetect.com files are important system files that are used by your computer to start the Windows XP operating system. These files can become damaged, corrupted or deleted for a number of reasons and are usually brought to your attention by the "NTLDR is Missing" error message.
Follow these easy steps to restore the damaged/corrupted or missing NTLDR and Ntdetect.com files from the Windows XP CD using the Recovery Console.
Time Required: Restoring the NTLDR and Ntdetect.com files from the Windows XP CD usually takes less than 15 minutes
Here's How:
Boot your system  using a Windows XP CD, press any key when the windows display "press any key to boot from CD"and wait for some time, select "r" option to go to recovery console. it will ask you for administrator password too.
When you reach the command prompt type the following two commands, pressing Enter after each one:
In the command listed above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\ represents the root folder of the partition that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite either of the two files, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that missing or corrupt versions of the NTLDR and/or Ntdetect.com files were your only issues, Windows XP should now start normally.
That's it.
Jan 22, 2010 | Acer Aspire 5315 Notebook
Ntldr missing, trigem dreambook, windows2000 P3 600Mhz
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the rootdirectory of the primary hard disk drive. For example, C:NTLDR andC:NTDETECT.COM should be the locations of these files on manycomputers.
  • Please keep in mind thatthese files are hidden system files, if you need additional help withviewing hidden files in Windows please see document CH000516.
Oncethese files have been copied to a floppy diskette reboot the computerand copy the NTLDR and NTDETECT.COM files to the root directory of theprimary hard disk drive. Below is an example of what commonly should beperformed from the A:> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Jan 13, 2010 | Microsoft Computers & Internet
NTLDR is missing error on starting the machine
When a PC system or notebook displays NTLDR is missing you can still recover with out re-installing windows. Follow the instructions on the link provided; http://www.computerhope.com/issues/ch000465.htm
Scroll down to: Corrupt NTLDR and/or NTDETECT.COM file.
The fix is a bit different for Win 2000 &Win XP.
Mike
Oct 17, 2009 | Systemax Neotach 3300 Notebook
Hello,pls I am having problem with my laptop IBM R30. Whenever I turn it on,It displays NTLDR file missing.MY mail is abincojay@yahoo.com
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers. Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516. Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive. copy ntldr c: copy ntdetect.com c: After the above two files have been copied, remove the floppy diskette and reboot the computer. Windows XP users Insert the Windows XP bootable CD into the computer. When prompted to press any key to boot from the CD, press any key. Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer. copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jun 05, 2009 | IBM Computers & Internet
Nldtr missing
Am I right in thinking you mean NTLDR and not NLDTR? If so here is the fix.
To fix the error on startup of NTLDR is missing in Win XP you should follow the steps below using a full version Win XP CD and the Recovery Console.
Insert the Windows CD and start the computer making sure the computer boots to the CD first.
When the Welcome to Setup screen appears, press R. (this may take a while to load)
Type a number corresponding to the Windows installation you wish to repair (usually 1) and press Enter. When prompted, type the administrator password and press Enter. (if no password was entered on you system then just press enter)
From the command prompt you want to copy NTLDR and NTDETECT.COM from the i386 folder of the CD to the root folder of the hard drive. This is much easier than it sounds and can be done by typing the commands below.
In the examples below C: is presumed to be your hard drive and D: is presumed to be your CD drive. You will need to change the drive letters to your own if you have more than one drive. ( if you are having problems entering \ then try pressing the # key to see if that works)
Type these 2 commands exactly and press enter after each one.
COPY D:\I386\NTLDR C:\
COPY D:\I386\NTDETECT.COM C:\
Now remove the Windows XP CD from the drive and restart the computer and your computer should now start normally.
http://ncane.com/vvb
Apr 22, 2009 | IBM Tripp Lite OfficePro 700 (10K1912) UPS...
Acer aspire 5100 nfltr is missing error
The best way to cure this problem is to install a new copy of windows xp. You have ntldr missing error, that means the problem is with the os loader. If you choose to reinstall os then please try to repartition and reformat your hdd.
You can find the drivers for your laptop at
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/au&siteid=8116&areaid=12&formid=3394#results
Nov 24, 2008 | Acer Aspire5100 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
