Tried to turn on my furnace this morning and got a code flashing on my Coleman Evcon unit. It is three flashing lights that indicate Combustion Air Switch failed to close.
  • timone1221 Oct 20, 2008
    I tried turning mine on as well and it's flashing three times. It worked earlier with my father's help, but I don't know what he did! lol
  • 182 Answers
Check for a blocked flue pipe
Posted on Oct 02, 2008
Indicator blicks 3 times replaced combustion air switch but did not resolve problem. what do i do now?
There should be a diagnostic chart on the furnace door by the wiring schematic. If so see what the code reads for three blinks.
By the term "air combustion switch" I guess you are referring to the pressure switch. Most diagnostics blinking three times is just a dirty flame sensor. If this is the case the burners will light and go out within 4 seconds. If this is the problem carefully remove the flame sensor and clean gently with emery cloth, fine sandpaper or fine steel wool. Reinsert the sensor and enjoy your heat.
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
there should be a diagnostic code that will tell you what 3 blinks mean for that model. look on door inside cover. tell me EXACTLY what it does at start up. small draft motor comes on? you see a glow from hot surface ignighter? gas comes on? flame on? it should run in this order.
I have a Coleman/Evcon furnace model #DGU08016UB that has a concern. In my attempt to check my furnace before we need it for the winter; the following condition occurred. Condition: Flashing code of...
jump out pressure switch see if it lights check hose to pressure switch see if they are split or connections are not good ,cut off ends and put back on presure switch.
Sep 21, 2011 | Coleman Heating & Cooling
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
Coleman evcon dgat090bdd. New ignitor won't heat up.
Looks like 4 flashes might be high limit fault on this furnace. (I don't have a manual for this furnace, just searched online for the code meaning) Is the unit running flame at all? Is the unit running flame for a while then shutting flame off before desired temp is reached? Does the main air fan turn on to circulate air through your diffusers? Does it feel like the unit has much air flow out of the diffusers if the fan is running? Is your air filter clean? If it is infact your high limit switch, it is usually caused by not having enough airflow through the furnace and overheating occurs.
Hope this helped, let me know if I can assist you further :)
Jan 16, 2009 | Coleman Propane Forced Air Heater...
Coleman evcon Dgato7obdc
Small blower motor? Are you talking about the combustion blower if so then check your vents for blockage.. if the vents are blocked won't work... if it has a control board init it will give you a diagnostic code. Flashing light on the board... count the flashes and look up the fault on the chart in your owners manual ot on the furnace door..
Jan 13, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
221 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
