Its a nec projection tv.model no. pj-465oen- its primary colors will form together at the middle,but will start seperating when it gets towards the ends of the top,bottom,and sides of tv, when ajusting the color test
    Problem Solver:
  • 18 Answers
Try adjusting the screen and focus adjustment on the flyback transformer for that.
Posted on Oct 02, 2008
SOURCE:
RCA rear projection tv picture bowed to middle. Red Green Blue colors have been seperated on screen.
If I had to guess I would say it's either the DLP chip or the prism. Simply put the lamp lights the DLP chip which directs the light into a prism and then onto the TV screen. The prism or prisms are responsible for aligning the colors correctly. The DLP chip is essentially a million little moving mirrors which direct light
If you're at all comfortable with electronics you might want to open the TV up to take a look. You might get lucky and find something obviously wrong with the TV. Sometimes adhesives melt and parts slip out of place. If your DLP chip is blown there isn't much you can do. You're probably right that this would cost a lot to fix and not be worth it.
Jul 24, 2012 | RCA Televison & Video
NEC ,model no. PJ-4650EN Projection
If you look into the Len's of each tube briefly when it is on and look at the quality of the picture. It sounds like the fluid is bad and should be replaced by a service company.
Sep 25, 2009 | Televison & Video
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Green on screen
try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Old projection tv NEC PJ-60PI circa 1972
You will want to find a local servicer for an honest tech to come out and check for bad connections on boards. It will be hard to find someone for a 1972 unit and parts even harder. If you are near Cleveland, I can help
Craig www.classtorations.com
Jun 08, 2008 | Televison & Video
Three colours don't converge
Shrink, the convergence circuit needs to be repaired, Until someone gets in there and takes a few measurements it`s hard to say what the cost will be, may just need to be re-soldered, good luck, BMW Rider
Dec 18, 2007 | RCA P46810LV 46" Rear Projection...
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Convergence and picture problems
This TV probably uses two convergence IC Packs that will need to be replaced and be re-converged. There may also be a resistor or two that may need replacing as well. The projection tubes should last another 3 years or so.
Dec 26, 2006 | Apex Digital GB43HD09 43" Rear Projection...
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Ekse
