Question about Kenmore Elite HE4 Electric Dryer
Back outside wall of dryer is burning
We have the Kenmore 417 dryer, about 9 years old. Lately the laundry hasn't been getting dry. After finding that lint was getting through a bend in the filter (different, though possibly related problem) and emptying out a huge wad of lint, here's what's happening. The dryer barrel heats up for the first 5 minutes or so. After that the barrel no longer heats, but the back side of the unit is extremely hot and even shows a burn mark. Does this sound like a timing or sensor problem, or is the motor fried from when it was blocked by lint? Thanks!
  • sehjones Oct 03, 2008
    Unfortunately we've done all that and the dryer still isn't functioning properly, which is the reason for the question.
  • 943 Answers
Hi. thanks for the question . pull dryer away from the wall. remove venting .clean venting to the outside. remove back panel. clean all lint first. cut power to te dryer . try again thanks the appliance doc. positive feed back .thanks the appliance doc
Posted on Oct 02, 2008
I have a kenmore 417 stacked washer and dryer that works but the dryer is slow to dry and the washer makes a squealing noise. what can i do to fix both?
Hello there Brian and welcome to fixya
Slow drying is a fairly common issue with dryers that are a few years old the most commmon problems is due to the following
Please check each one of these very close ok
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 18, 2012 | Kenmore 98702 Stacked Washer/Dryer
I have a Lady Kenmore electric dryer (40 years old maybe?), model 110 6508923, which I cleaned the vents, strong air, tumbles fine. The heating element glows orange for a few moments, then as it finally...
The element is supposed to cycle on and off thru out the drying cycle as not to burn clothes. Is it just taking too long to dry. If it is your exhaust from the wall behind the dryer to the outside is clogged somehow. I like to use a leaf blower stuck inside the exhaust behind the dryer and blow the whole line out to the outside of the home.
Jan 31, 2010 | Dryers
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
Dryer gets hot and drum is turning clothes are not drying. cleaned lint tray and removed tubing venting outside and the dryer is making a whining noise. the dryer is only 14 months old
If the drum is turning and the dryer is getting hot, then this is good news, as it means that the dryer is mechanically sound.
First check to see if the internal workings of the dryer are not blocked by running the dryer with the vent tube detached. If there is lots of warm moist air coming out the hole in the back of the dryer where the tube should be, then your dryer is fine.
Next, if you've checked the tube that connects the dryer to the wall or floor and it is clear, then on to step 3.
Probably you have a blocked or severely restricted vent tube from the wall or floor to the outside. Over time, these always become clogged with wet lint that builds up into a crust on the walls of the tubing.
Find the exhaust exit on the outside of the house and run a sewer snake up into it to see if you can open a hole in the blockage. If that works to help the air flow, then you need to replace the tubing from your laundry room to the outside, as it is probably a solid crust of lint that has built up over years.
Again, the good news here is that your expensive new dryer is probably fine.
Jun 10, 2009 | GE Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Hot side wall and staus lights stay on
repl/ hi limit and safety thermostat,, will solve prblems
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Venting a dryer outside
What do you need to reverse?
I understand that the wall kit is to blow the heated air from the dryer to outside therefore not humidifying the laundry.
Are you trying to draw air into the dryer from outside or blow the air outside?
Sep 14, 2008 | Fisher and Paykel DE06 Electric Dryer
Dyer has power but doesn't start
dryer inside is very hot, 6 years long time, i have the feeling that wire was damaged and connected to each other cause this kind problem.
Jul 06, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer not drying
try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Jan 16, 2008 | Amana NDE2335AY Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
94 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
