Question about Garmin GPS
GPS V at startup it goes to second screen and shuts down leaving a line across the bottom of the screen.
  • capitolotx Oct 22, 2008
    I have exactly the same problem. It's really interesting though...I can take the device into my office and turn it on and it will run for hours, on simulation. It just seems to have issues after it actually gets a lock on the satellites. Oh no, another governemnt conspiracy!!
I contacted Garmin and they actually researched the problem and got back to me with a solution a few hours later. I have already instituted it and it works. Here's what they suggested:
Thank you for contacting Garmin International. I will be more than happy to help you with this. The situation you described appears to come from a change in the WAAS system by the government. To correct this issue you must turn the WAAS off. To do this turn the unit on and press the menu button twice. Next highlight setup and press enter. Under the system tab, WAAS is located in lower right hand corner. Scroll down and over to highlight enabled, press enter and change to disabled. Engineering has been informed however due to the discontinued status of this unit we are not sure when ( or if ) a new unit software will be issued to correct this problem. I appologize for any inconvienience.
Hope this helps!
Posted on Oct 23, 2008
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
When I start Vista the startup bar shows up and then power goes off to the screen and the computer re-starts again and again. I get the black screen safe mode screen also. Additionally, I.E. shuts down...
Windows is toast, my friend. I hope you have a good backup, and recovery disks. It's probably malware, but the bottom line is Windows needs to be reinstalled.
Nov 20, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
The Startup repair program is running and wont stop
A complete scan can take several hours to complete. If you want to shut it all down unplug it and remove the battery. Leave the battery out for at least 10 minutes, and until it cools down.
Nov 04, 2009 | Computers & Internet
Shuts off after startup
did you ever get this corrected mine started doing this today as well.
Jul 11, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
After several munutes of on the screen goes to
I have a Garmin Street Pilot c330 which when plugged in and power button pushed, the screen lights up for a few seconds and shuts down. It was giving a low battery warning before shutting down. Where is teh battery in teh unity? and should I replace the fuse?
Apr 22, 2009 | Magellan Maestro 4040 GPS Receiver
Power
Sounds to me like its your green tube. Kind of expensive replacement, but easy.
Jul 24, 2008 | Sony KP-51HW40 51" Rear Projection...
SONY KP-46WT520
does the led blink when it shuts down if so how many times does it blink? And the green line is that running up and down the screen or across the screen?
Apr 26, 2008 | Televison & Video
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
