Question about Toshiba Satellite A215-S7422 Notebook
BIOS PASSWORD I forgot my bios password .Can you please give me a solution to get out of this problem.
Toshiba satellite a215-s7422 laptop bios password how to cleare
Posted on Feb 21, 2009
    Sergeant:
  • 268 Answers
There is a trick to resetting the BIOS password , but it requires you to open the laptop and get to the motherboard. Now I don't know your level of expertise in that field , but laptops can be very trick to pull apart and put back together...so if you are not comfortable doing it , please take it to a professional as I don't want to see you damage your laptop!
Back to resetting the password......you need to access the motherboard of the laptop....on the motherboard is a small circular battery (it is flat and silver)..... that needs to be disconnected from the motherboard to reset all the BIOS information...depending on the model of the laptop , you may be able to completely remove the battery from the clip it is in , or you may need to disconnect the wire running from the batter to motherboard. Below I have put some example pictures to make it clear.
Removing That Battery:
Disconnecting The Cable:
After disconnecting it/removing it place it back in/reconnect it , put the laptop back together and boot up....the password will be reset! Below is a picture just in case you have trouble finding the battery
If this post helped you please leave a rating, it is well appreciated, thanks!
Posted on Oct 02, 2008
  • 98 Answers
SOURCE: crack bios password on compaq nc6320 - please
My best suggestion is to call Compaq or HP for assistance regarding on this. Thank you.
Posted on Oct 09, 2009
Testimonial: "thanks - I like to do things myself, but I will call them - "
  • 74 Answers
SOURCE: Forgot BIOS password
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Oct 17, 2009
gomartymo
  • 20 Answers
SOURCE: forgot my bios password please help benny
There are a number of reasons why we might set a password to protect our BIOS from changes. The problem is that we only need to go in there once in a blue moon, making the password easy to forget, locking everyone out. I had a situation many years ago where a colleague suggested the purchase of a new motherboard because they couldn’t remember the password. I got that little bit more frustrated with my job that day.
There are various options you can use to get back into your BIOS. All of them reset the BIOS back to default values, so make sure you’ve tried all of your regular passwords before attempting these methods. I have tried to keep it brief…
Newer Computers: Most newer motherboards have a jumper on them, which you can change the position of to reset the BIOS. Find your motherboard manual or search for the motherboards model number in Google. You want to find a diagram showing what and where various components and jumpers are on the motherboard. The manual should tell you which jumper needs to be changed.
Once you have changed the jumper, return the jumper back to its original position while the machine is off. You don’t want it to keep resetting itself. Turn on the machine and go into the BIOS. All options will be open to you.
Older Computers: The quickest way to get into the BIOS of an older computer that has been password protected is to remove the battery. The battery keeps the system clock going. Once you remove it, you can put it back in and start the computer.
When you start your computer, you will find your BIOS has been reset to its default values. You are now able to change any settings you want.
General: Some motherboard manufacturers have a secret password that will work, overwriting the password already locking the computer. These are readily available online with a bit of a search. I think this is becoming less common with time.
For more information on the methods above, tech-faq has a great article which goes more in depth.
Posted on Oct 26, 2009
Steventheone
  • 94 Answers
SOURCE: i forgot the bios password
Very simple...
Contact HP tell them to provide you with the step's to remove and reseat the CMOS battery then they would provide you with a manual...
Use the manual and reseat the battery...
Done..
Issue resolved...
Posted on Jun 12, 2010
shashank rai
  • 60 Answers
SOURCE: Eee Pc 4g Asus BIOS password forgoten
this passsword can be onky given by your coustmer service center
Posted on Jul 17, 2010
Forgot bios for sony vgn-SR19XN
Bios passwords on laptops are only over rode by the the manufacture. This is because they are easy theft items. IBM for instance have a government contract so they will never offer you support for that. You can prove ownership to Sony they may have a master password. Good luck though not heard any company yet that will give that info over the phone. There is NO work around for a that other than Sony doing it.
Mar 23, 2014 | Sony Vaio PCG-7F1L PCG-8A1R PCG-8C3L...
I forget my user password so what i doing.
Forgot Bios password?
Well,I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Use the bios password recovery tool from biospasswordrecovery.com!
So these my suggest for u. Hope it helps.
Jun 07, 2012 | Intel D845GVSR Motherboard
How to remove bios password from dell laptop
You can reset bios by doing bios battery repluggingMost commonlly CMOS battery is coming at the backside of keyboard
Follow these step
1. Remove keyboad2.there is you can see a two wire pin3. Unplugg pin and replugg after 5 minNow your bios is resetted
Thank you
Apr 04, 2012 | Dell Computers & Internet
I forgot my password on a dell inspiron N5110 laptop
i forgot DELL INSPIRON N5110 ADMIN BIOS PASSWORD......HELP
Jan 19, 2012 | Computers & Internet
I want to remove a ASUS Eeepc 4g bios password which i forgot please guide me thanks.
http://www.unlockbiosrecovery.com/Unlock_ASUS_Bios.php can calculate a bios master password for your ASUS notebook for $20 and they guarantee it to work. The bios master password will clear the currently set bios password, giving you full access to bios setup. I repair laptops and I use them when I get a laptop with an unknown bios password or unknown hard drive password and they have always worked for me.
Sep 06, 2011 | ASUS Eee 4G Notebook
Forgotten password
Is it a BIOS password or an OS password?
if its a BIOS password it will be hard if its a OS password you can try forgot password solution if that is available or else you need to reformat it if there are no other admin accounts
please give more details
Mar 23, 2011 | Packard Bell Computers & Internet
Forgot BIOS password. When i start the PC it gives as black screen with lock symbol..i entered the incorrect password for more than 3 times,,Please HELP !
you should try to dopen it up, locate the cmos battery, plug it out for about 30 minutes and put it back then test if bios has been cleared. if not, try to google and find out backdoor bios passwords for your model. hope this helps.
Mar 15, 2011 | IBM ThinkPad R40 2722 Notebook
My wipro notbook MODEL WIVNB7710 I can't boot they asking bios password so plz give me solution
insert bios password that you insert in your bios
if you forgot it, plug off bios battery and then plug on again it will reset bios password, but be carefull usulally bios password is in mainbard be carefull if you dindt wish to have more damage
i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 20, 2011 | Computers & Internet
Eee pc forgot bios password
Too bad pal. Now open it and remove the button cell that is there on the motherboard. Insert it back after a minute or so. Re-assemble the laptop and remember never to give a password anywhere.
Aug 24, 2009 | ASUS Eee PC 701SD 8G Notebook
I NEED A PASSWORD TO OPEN MY DELL SYSTEM LAPTOP
You need to find a BISO/CMOS password reset tool, try googing them.
Apr 27, 2009 | Dell Latitude D600 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
602 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
