NO, it doesn't answer my question. I want to know if a ZPad can be used as an e readerNO, it doesn't answer my question. I want to know if a ZPad can be used as an e reader
You can't post conmments that contain an email address.
Lenovohttps://download.lenovo.com > mobiles_pdf > l...
PDF
Note: Before you start, print these instructions and the instructions on "Lenovo Tablet Setup app" on page. 27. You also can screen-capture the instructions and ...
86 pages
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
are a set number of recharges that equate to the life of the battery. Usually that life is
approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the
battery is used up, the maximum charge lessens which means where you may have had 8
hours of play time when the battery was new, you will only have 6 hours as the battery life is
used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge
left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never
recharge again or the max charge will be reduced to an insignificant amount of the original full
charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries
cannot have their batteries replaced.
