Question about Mitsubishi Heating & Cooling
Mitsubishi MSO9E/MSM18E series Split type air conditioners
Hi- My unit turned off automatically then had a "check P6" message on screen.  What does that mean?
Therinnaiguy
  • 1420 Answers
SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Posted on Aug 30, 2007
bobotfel
  • 236 Answers
SOURCE: Split System Air conditioner
If it is water leaking check the indoor drain pan if overflow with water.If the pan is overflow with water then you need to clean your drain pan and drain pipe. While the unit is operating check the drain pipe if water drip, if no water coming out from drain pipe you need to flush it with water to flush out the restriction.
Try also to check if no icing build in the evaporator fins. If icing is present then you need to clean your indoor evaporator pins and air filter. But if it is clean and still icing is present then your unit is out of gas.
Posted on Jan 29, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
SOURCE: Westpoint split air conditoner remote contol unit
I want to locate a Eolia West Point A/C remote
Posted on Oct 23, 2008
SOURCE: Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
Posted on May 29, 2009
Hello my problem is that my lg ac is not automatically starting when power comes back .please tell me solution how ac can turns on after electricity comes back .thanks
Unfortunately there is no way to make it come on after the power outage without physically pushing the "on" button on the remote or the indoor unit.
It is a big problem with many on the split type A/C units.
heatman101
Apr 30, 2011 | LG LS-L1210CL Mini Split Air Conditioner
HOW WE CAN SET THE SPLIT UNIT TO BE WITH POWER SUPPLY RECOVERY FUNCTION? I MEAN WHEN POWER SUPPLY TRIP AND RESET AGAIN WE WANT THE UNIT TO START AUTOMATICLY WITHOUT PRESS ON SWITCH
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 15, 2010 | Mitsubishi Heating & Cooling
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 24, 2010 | Mitsubishi MS09TW Air Conditioner
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
The heat is not getting hot and keeps turning off
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
heatman101
Jan 31, 2010 | Mitsubishi MSZ-A15NA Split System Air...
Mitsubishi split system will not start no green ligths come on on wall unit
heatman101
Jan 09, 2010 | Mitsubishi MS-A09WA Split System Air...
Hi,mitsubishi ms12tn mini split ,when i put on the
There is small PCB in the AC, this PCB is malfuctioning also there is automatic ON /OFF switch Check whether ti is working properly or not.
Oct 02, 2009 | Mitsubishi MS12TN Air Conditioner
My Samsung air conditioner which is of split type is not operating. It is of the AS185 series. There is a red-light that is on. This has never happened before. It turns on momentarily and turns off again...
After 15 months of used my Split type A/C model AS18F series suddenly not cooling, I unplugged the unit and clean the Air Filter as well, but still the problem exist.
Apr 19, 2009 | Samsung AW1003M Air Conditioner
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
