Question about Kitchen Appliances - Others
Thermastat and furnace
I have a very old thermastat and the cover isn't there anymore. The problem is about 1 month ago the furnace was turned on by mistake and no problem it came on. Now since it's cold I turned the thermastat on and it won't turn the furnace on. The pilot is lit. Please help
Turn the power off to the furnace. Take your thermostat off the wall. Disconnect the red and white wire off the stat. Tie those 2 together. Turn the power to the furnace back on. If the heat comes on, the thermostat is bad. If it doesnt come on, then you may not have power to the stat. Possibly a bad transformer in furnace.
Posted on Sep 20, 2012
    Novelist:
  • 124 Answers
You should have 24 volts between yellow and white wires at the stat when the stat is set to heat and set as hot as it will go. burners should light first then 3 to 5 minutes later the fan motor should fire up. if burner doesn't light check the wires going into the top of the gas valve see if you have 24 volts arriving there from the stat. if you do then the gasvalve is probably bad. you can bypass the action of the stat by jumping red to white on 90 percent of the stats made and in a few seconds the gas valve should click open gas flow to main burner where pilot ignites it. another easy check you can do is flip stat fan switch to on. fan should come on at once. if not then you have either no high voltage to unit or no low voltage ( as in a bad transformer). if the fan comes on you know you have high volts and low volts...by cover i assume you mean the decorative cover but there second cover with the mercury bulbs and all is still there. if you have only the bare subbase then new stat time. sounds like an old furnace if it has a standing pilot, it should be checked for cracked heat exchanger by a pro with a n electronic carbon monoxide detector. NOT a diy item due to the real danger of co poisoning.
Posted on Oct 09, 2008
Induced draft gas furnace will not turn work
Check the 3-5 amp fuse on the control board of the Furnace, tell me if the fuse has a burn spot on it.
Dec 19, 2012 | Heating & Cooling
My furnace is not reaching the temperature the thermastat is set to so we replaced the thermastat and now the furnace continues to run sometimes the air is warm and sometimes the air is cool.
you haven't given enough information. Is your system forced air? If so it may be a problem with too much cold air mixing with vent damper.
Jan 25, 2011 | Heating & Cooling
When the thermastat turns on the furnace doesn't ignite the burners and the pilot light is lit. Everything appears to be normal, fan runs, thermastat appears to work properly.
You may have an open limit or a bad gas valve. Check and see if you get 24 volts to the gas valve, if you do then you gas valve has gone out.
Oct 06, 2010 | Heating & Cooling
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
New Furnace Coleman Model 8623A Ser#037873318
Red wire to R. There may be a R, Rc, Rh, You will have either one or 2 of these. They shaould be jumped together with a small jumper from the factory. Then white to W, green to G and yellow to Y
Mar 20, 2010 | Coleman Heating & Cooling
Blank Thermastat LCD
check power to the furnace.
Aug 10, 2008 | Carrier 38CKC036 Air Conditioner
Central air conditioner
check the filter also sounds like a low freon charge.
Jul 29, 2008 | Ruud UBHC Air Conditioner
AC fan not blowing/ Honeywell T87F thermastat
ok heres a test i want you to do carefully remove the thermostat cover and you will see the 3 wires one is red the other one is yellow and a green one turn off the thermostat and remove the wire from thermostat labeled G and carefully touch it on the R terminal if fan turns on, thermostat is defective if it dosen't turn on there should be a fan section on control board that's defective
Jun 26, 2008 | Weather King 10AJA2501AH Air Conditioner
Kitchen Appliances - Others Logo
245 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
