Question about Dryers
I need to replace the timer - Dryers
  • Dryers Master
  • 19,396 Answers
If you want to do it yourself, click on this link: Appliance Parts From PartSelect | Repair Parts For Major Appliances.
Insert the model number and get part diagram to install it and part price to buy it.
If they do not have the part, call them or try here: RepairClinic.com
If you do not find the part online, post a new question on Fixya, specifying the model number.
If you decide to call a technician instead, use the number listed on the appliance user manual.
Posted on Oct 02, 2008
Do i need to power down to change the back up battery
If this is ordinary residential timer, you can replace battery without changing anything.
Just replace battery.
Most timers will hold some or part of the memory during battery changeover... frequently losing no programming if battery change is done quickly, and battery was not completely depleted, and timer is still functional.
If timer function is not restored after battery change, reset timer fully and then reprogram.
If battery change and reset does not work, then timer is probably gone bad.
Most modern timers have reset button, but some require a 2-button sequence to reset.
Other modern timers have a 'battery' but the battery is built into the circuit board and thus not replaceable ... it is rechargeable, like a capacitor ... but when it fails .. the timer needs to be replaced.
Timers with replaceable batteries are generally not functional after exposure to freezing temperatures for several day, but the non-replaceable type generally have wider tolerance for temperature variation.
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/Programmable.html
Gene
Water Heater Timers Save Money
Mar 23, 2015 | Hardware & Accessories
Intermatic t10004rt3 pool timer cycles a loud hum/buzz noise like bad contacts or relay
T10004R control center has one T104 240V timer, with extra space for another timer or freeze control etc.
You can clean up the timer and replace clock motor to stop most noises.
The T104M (M for mechanism-only, snaps into the control center enclosure.
The T104 also snaps out of enclosure using thumb spring located top inside box.
Take image of wires before disconnecting from timer.
The T104 is identical to WH40, same parts, same trippers, same appearance, except with different override lever.
Here are photos of WH40 showing how to take apart timer and clean it, also with links identifying replacement parts:
http://waterheatertimer.org/Photos-of-WH40-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
If you need to replace timer, it is cheaper to buy the ordinary T104 that comes inside a box and can be snapped out, instead of buying T104M (M for mechanism-only)
Gene
h
Apr 10, 2014 | Intermatic Hardware & Accessories
Tries to drain water when its empty.
The timer is out of sequence and will need to be replaced. Here is the new timer you need.
Here is a video to walk you thru the replacement process.
Oct 19, 2012 | GE WBSR3140DW Top Load Washer
Dryer timer will not advance in any mode.. timed, or auto mode. Dryer works, but will not turn off unless you open door or advance timer. Do I need to replace the timer?
the timer will need to be replaced if it's stuck in the mode as you stated. the timer is built with cog teeth gears that rotate slowly as the timer operates normally. If a cog tooth breaks off the timer is stuck in that position causing your problem here
Jul 11, 2011 | Whirlpool LEB6200 Electric Dryer
My ge washer wbvh6240hww wont advance in time
the timer motor on the timer that advances the timer is defective,replace the entire timer as a motor for the timer will be just as much as a timer if its available separatelyanyway
May 16, 2011 | General Electric WBVH6240HWW Front Load...
Clock Stopped Turning
Most likely, the timer motor has failed and needs to be replaced. As the timer motor is constantly running 24/7, getting 19 years of use is significant and is well beyond the typical life of a mechanical timer of this type. I know, I've got the same ones on my pool and usually have to replace them every 10-12 years.
As the timer IS 19+ years old, it would be best to replace the entire unit instead of looking to tyr to get just a replacement timer motor, since the cost for a new timer isn't all that much compared to the cost for just the motor.
Intermatic also makes a digital timer version of this type of timer, but for the relatively low price of a new, replacement mechanical timer, it might be a good idea to get another one like you have and expect another long working life.
Sorry that there really isn't much to repair in such an old timer, since the motor is the critical part.
The replacement should be easy to do yourself, just remember to turn off the power breaker and disconnect the power to the timer. All you need to do is exchange the wires into the new replacement timer I find that taking a picture of the timer as it is, will help you get the connections correct for the new timer.
Also, check the model number of your present timer and voltage, (some pool equipment is 100V-AC while others are 220V-AC) to get the correct replacment timer.
Hope you find this Very Helpful and best regards.
Sep 09, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Timer runs backwards
looks like the timer is starting to fail,hope this helps
May 27, 2009 | Kenmore Dryers
How to replace clock in intermatic timer
I need to replace the timer on a model #ML600TW
Apr 29, 2009 | Hardware & Accessories
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Dryers Logo
203 people viewed this question
Top Dryers Experts
