Question about Philips 15MF150V 15 in. HDTV-Ready LCD Television
Magnavox 15MF150V/37 travou num canal os controles nao respondem
Nao consigo nenhum controle sobre o aparelho (nem no controle remoto, nem das teclas do proprio aparelho. Esta tudo travado. quando aperto as teclas menu, volume e etc., aparece, no video a mensagem abaixo (so funcion a tecla on/off):
ATTENTION
OSD MAIN MENU LOCKED
o que fazer??? agradeco a atencao.
5 Suggested Answers
  • 52 Answers
SOURCE: Phillips 37PF73203 37 in Television goes straigt to Menu and stays
verify in customer menu, installation, software upgrade, current software info that software is 1.5.0.0. if not upgrade by downloading from p4c.philips.com website and upgrade via usb memory stick. if upgrade is successful and menu still pops up would be a small signal board issue
Posted on Aug 18, 2008
SOURCE: osd menu locked
had exactly the same problem, hold down the menu under the screen for about 10 to 30 seconds, the osd warning disappears and the blue menu should come up.
Posted on Sep 19, 2008
SOURCE: placa pci philips saa7130
mkighbk
Posted on Sep 23, 2008
CAYPIANAN
  • 227 Answers
SOURCE: solo enciende, inactiva demas funciones
hola tienes que chequear la fuente de alimentacion o power supply
si abres el tv vas a ver algun capacitor que esta alterado osea como prenado cualquier pregunta me puedes enviar un mensaje a mi correo electronico\;
buena suerte
caypianan@yahoo.com
Posted on Jan 01, 2009
  • 3 Answers
SOURCE: Can't exit the menu screen!
you need to do a firmware up date on the tv had the same trouble
Posted on May 15, 2009
Como se reativa a fn?
Dear Ary,
I'll first answer in English and then in Portuguese..
The 'Fn' key is not reactivated. As a matter of fact, it 'activates' the special functions marked in the same color or with the same pattern as is shown in the 'Fn' key. Pressing and holding the 'Fn' key while you press any of the function keys will enable the function marked on those keys (increase or decrease brightness, increase or decrease sound, open the DVD player, lock/unlock the laptop, start the browser, etc).
In the case your problem is that the 'Fn' key is not performing the actions described, along the other function keys, maybe it could be caused by a defective contact matrix under that key. In this case, you will have to take your laptop to an authorized service repair shop and have its keyboard repaired or replaced.
Hope it helps!
Agora em Portugues:
A tecla 'Fn' nao e reativada. Na verdade, ela 'ativa' as funcoes especiais das teclas de funcoes (marcadas de F1 ate F12 no topo do teclado) que estao na mesma cor ou com o mesmo padrao da tecla 'Fn'. Pressionando e mantendo pressionada a tecla 'Fn' enquanto voce pressiona qualquer uma daquelas teclas permitira executar a funcao marcada nas mesmas (aumentar ou diminuir o brilho da tela, aumentar ou diminuir o som, abrir o browser, bloquear ou desbloquear o laptop, etc).
Se o problema que voce menciona e o da tecla nao cumprir com essa funcao de ativar a funcao das demais, pode ser que a matriz de contatos do teclado esteja gasta - ai sera necessario levar o laptop a uma assistencia tecnica para reparar ou trocar o teclado.
Espero ter ajudado!
Miguel L. Martins
(P.S.: nao uso os caracteres acentuados porque o sistema da Fixya nao permite caracteres Unicode, somente caracteres em ingles).
Nov 05, 2013 | Acer Aspire One PC Notebook
Meu telefone perdeu todas as funções gostaria de rest, ou não sei se da pra formatar ou fazer o bot que nem o pc. Não sei mais que faço.
Alo grande.
Em primeiro lugar, eu so formatei ate agora Nokia 6600 e nokia N73 com os mesmos codigos.
Mas tu podes usar o mesmo codigo para alguns outros telemoveis.
Faca o seguinte Apos carregar bem o cellurar.
1 _ desliga o celular
2 _ volta a ligar o celular.( em seguida pressione logo nas seguintes teclas: Verde de atender, tecla 3, e tecla ASTERIX *. tudo ao mesmo tempo...) ate sair um sinal k seu celular esta ser formatado.
Se nao der, digite os seguintes codigos.. *#7780# ou *#7370#
Boa sorte
Nov 25, 2010 | Computers & Internet
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
QUIERO LOS CODIGOS PARA TV PHILIPS, SE ME PERDIO EL MANUAL DE INSTRUCCION DEL CONTROL UNIVERSAL DURABRAND 1 X CR2032. DESDE YA MUCHAS GRACIAS............ SALUDA ATTE. NOCHO VIALE
en la mayoria de los remotos universales viene una tecla que dice "CODE" si es tu caso:
1.- enciende tu tv
2.- oprime CODE y manten oprimida hasta que led indicador quede encendido
3.- pulsa tecla "POWER" las veces que sea necesario apuntando hacia la tv hasta que se apague.
4.- cuando se apague no des mas pulsos a POWER y oprime tecla "ENTER"
si por alguna razon te pasas y das un pulso de mas a POWER, repite la accion.
suerte.
Feb 16, 2010 | Televison & Video
I need the code for my "sony" universal remote control
SI esta utilizando un remoto marca phillip solo daja presionado code la luz se encendera luego pincha tv y con el botton de cambiar canal le das up varias veces hasta que el tv cambie de canal y luego le das enter y listo
Apr 13, 2009 | Sharp LC-26D6U 26 in. LCD Television
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Philips 15MF150V 15 in. HDTV-Ready LCD Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
