Locked on `paperjam
On first card thro`pass-.card was stopped by object behind printer.object removed but printer detected paper jam. no damage to card or jam in printer but after off/ on printer still displays `paperjam` even after long power off.no function from any button - cannot clear the state.
edward 367
  • edward367 Oct 06, 2008
    this site fails to respond to the fact that I did not ask for help with tv
    only for help with a printer. the advice given did not fix the problem
    the printer is now at a repair shop.
    Edward.
I do not need the premium plan . please understand. I DO NOT HAVE A TV PROBLEM.
my request was for a problem with a canon printer . your suggestions were of no help . it is now in the hands of a repair shop. I trust that you will not charge
for the uncuccessful attempt .
Edward.
Posted on Oct 06, 2008
I've got a paperjam HP Deskjet 3050A--no instructions on how to fix. Please help! I have an impending deadline!
check paper loading area and printing area is there any paper jammed? remove any viable objects, If printer in warranty surrender to HP. check paper path sensor...
Jan 30, 2012 | HP Office Equipment & Supplies
Hi there...we have an error saying paperjam - code=007. I have checked for paperjams and there doesnt visually appear to be any. What can you suggest?
When you removed paper from the machine, did it rip at all? If it did, a small scrap could have been left behind, causing the jam code. Depending on where the machine is located and who uses it, there might also be a foreign object lodged in it (like a staple or paper clip). If you think there is nothing in there causing the jam, try turning the machine off and turning it back on, and see if it still shows the jam.
May 27, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
I keep getting a paper jam message but there is no paper jam. any idea????
There may be a piece of paper still stuck in the unit. If a paper jams in a printer, you should assemble the torn sheet and make sure all the pieces came out.
Forcing a jammed sheet out of a printer can damage the paper detect arm. This arm is usually near the platen (The roller the head prints against) to detect the paper as it passes.
Mar 28, 2010 | Canon PIXMA iP1600 Printer
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Paper jam light on
the censor that detect presence of paper in the printer has stopped working. check it if you can or get it repaired from local sevice centre......
Sep 29, 2009 | Sharp AL-1217 Copier
Oki B4250 PaperJam
clean and wash paper transfer roller or feed roller guide it fail timing
Sep 10, 2009 | OKI B4250 Led Printer
Selphy 720 !st card pass.card stopped partway by power lead-carelessly placed.no paper jam.But display now permanently shows paper jam symbol- not cleared by off/on. no function from any button. ...
Start first unplugging power for ten minutes, and see if it clears the error.
If it does not inspect the printer for paper or foreign objects, take out cartridge and put it back, see if this helps.
Oct 02, 2008 | Televison & Video
E-04 paper jam
Hi, my printer did the same and following the instruction of turning it of and clearing any jam didn't work. In the end I forced a sheet of paper into the printer intake at the rear of the machine and turned it off. The printer then took the sheet in about a third of the way. When I switched the printer on the sheet was then drawn through and out the front as if it were printed on. I think the printer has some sensors which must detect a sheet passing through them for it to reset. Hope this works.
Sep 23, 2008 | Epson Stylus DX6050 All-In-One InkJet...
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Televison & Video Logo
Top Televison & Video Experts
