Question about Cameras
I have just bought a brand-new Canon 450D - a lovely camera, but my computer will not open the EOS Digital Solution Disk (v18.0), quoting: 'the screen resoluion is not sufficient'. My Pc is not THAT ancinet. How can I solve this, please? Thanks for any advice!
I managed to alter the resolution on my PC through right-click -> properties -> settings, after some telephone advie from the Canon folk.
Posted on Oct 03, 2008
What is the latest firmware for canon 450d?
1.1.0 and this site from Canon, you can download the firmware.
Canon EOS REBEL XSi 450D Firmware Download
Only when you have a new lens, not yet supported by your came, I would get the firmware.
Jul 26, 2014 | Canon EOS 450D Digital Camera
I have a canon eos rebel xsi 450D. i loaded the eos digital solutions disk on to my windows xp computer. it seemed to load fine. the memory card manager screen appeared on my computer.then a small EOS...
Not a good idea to post your phone # and e-address on this or any other site.
This question arrived on FixYa.
Problem is the camera firmware isn't compatible with the software possible needs a Canon free update or purchase a card reader and download your pictures stepping around the camera.
The computer will look at this card reader with the memory card installed as an external hard drive or memory device.
Download you pictures and then do a safely eject or eject before removing the memory card, once back in the camera remember to format the memory card this give the camera a nice clean surface to work with again.
Apr 17, 2011 | Canon EOS 450D EOS Rebel XSi Digital...
I have windows 7 and it dont work pls help
Click Canon Support link and download driver updates for Windows 7 and install in your computer.
Hope this update will solve your Canon EOS 450D connectivity problem with computer.
Thanks.
Feb 17, 2011 | Canon EOS 450D Digital Camera
EOS 450D Digital Camera: will not download images to laptop...
USB SOCKET IS FAULTY YOU CAN OPEN CAMERA AND REMOVE MAIN PCB AND SOLDER USB SOCKET CONNECTION
May 18, 2010 | Canon EOS 450D Digital Camera
Canon EOS 450d not clicking on AF mode
this may have to do with the lens rather than the camera, try swapping the lens with another one and see if the same problem happens in AF mode with the new, borrowed lens, also remove lens and check that the gold connector between the two are clean carefully wipe with a dry q tip but be careful not to allow dirt to fall into camera body.
Apr 12, 2010 | Canon EOS 450D Digital Camera
Card write protected
Check if the card is truly write protected (check the little slider on the SD card). Its possible it slid into lock position accidentally
Nov 25, 2009 | Canon EOS 450D Digital Camera
My canon EOS 450D battery loses power within 5mins
If it's an original battery, call Canon, if you've only charged it once, I expect the camera is still under warranty. I've had lots of dealings with Canon Photography, the usually give extremely good customer service.
If it's a cheap one you bought of ebay - that's why!
www.yourhandinmine.co.uk
May 16, 2009 | Canon EOS 450D Digital Camera
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
