Question about Samsung HLP4663W 46" Rear Projection HDTV
Screen position needs adjustment
I changed out the color wheel on my HLP4663W and the quality of the picture is great. The problem is that the entire picture is about 1" below the screen, and I need to adjust it up. Any ideas?
Turn the TV off.  Press "Mute" 1 - 8 - 2 "Power".  This will open the service menu.  You can adjust the vertical and horizontal position from the first or second menu item.  Just be careful not to change any other settings and to record original settings.  Turn the TV off to exit the service menu.
Posted on Nov 09, 2008
Try opening up the back and the chip with the thousands of mirrors can be adjusted and the should be 4 screws holding it in place but then you could also be pplaying with the focus as well i'd recommend it being a two person job
Posted on Nov 05, 2008
No color
This tv have a colors wheels it dead,it spinning off of it axis.That why u getting black&white picture.Hire a tv tech. to change the colors wheel.Because it hard to change the colors wheel,u never done it before.Have to take out alots machanicals parts before even can get to the colors wheel to change it.
May 14, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My Samsung HLP4663W 46 in was making a buzzing noise for several months. I know it could have been either the fan(s) or the color wheel, but I never opened it up to determine which it was. Now the TV quit...
Great reasoning work! In fact, the lamp will not light if the color wheel does not spin-up. Fans will not stop the process of lamp ignition. Instead, a fan will be detected and a message will appear on the screen telling which fan has stopped. You need to have the color wheel replaced.
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLP4663W Black Solarization
The speed of the color wheel needs to adjusted or the CCA values. Both are found in the service menu . If you paid a company to fix the TV, call them and tell them that they forgot to perform these alignments. If you did the repair yourself, you'll have to call around for a price to have a Samsung service center perform these adjustments. I don't recommend consumers access the service menus of modern TVs because one wrong button push and you may cause irrepairable changes to the TV's proper operation.
michtech
Feb 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Replaced lamp & color wheel, no picture
Check your old lamp. Do you remember what its condition was like. If the tube inside the lamp was shattered into a thousand pieces that is a sign of ballast problems and that is where you should start to look. After all the ballast is what runs your lamp.
Sep 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color wheel replacement
I have the same problem. Iet me know if you get a solution.
Brandon
brand43076@charter.net
Apr 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
220 people viewed this question
Jerry Greenberg
Jerry Greenberg
