Selphy 720 !st card pass.card stopped partway by power lead-carelessly placed.no paper jam.But display now permanently shows paper jam symbol- not cleared by off/on. no function from any button. Ted.Lark.
  • 19,396 Answers
Start first unplugging power for ten minutes, and see if it clears the error.
If it does not inspect the printer for paper or foreign objects, take out cartridge and put it back, see if this helps.
Posted on Oct 02, 2008
  • Ginko
    Ginko Oct 02, 2008
    Canon selphy 720 is quite a delicate printer.
    Unplug power first.
    Turn off then on the printer a couple of times.
    Inspect the inside of the printer for foreign objects.
    Try removing cartridges and putting them back.
    If it still does not fix the error, is better to call service number, as suggested at page 48 of the manual here: SELPHY CP730/CP720 Printer User Guide
Paper jam on display but there's no paper jam
Then the roller are dirty or need to be replaced because they cant grab the paper so the machine is miss feeding jam is when the paper hit something or stop electrically move to different draw or the by pass
Jul 25, 2012 | Minolta bizhub 200 All-In-One Printer
How i can clean my printer selphy ES30 also how to solve an error paper jam
For Paper jam:
• Press
(BACK) to eject the paper.
If the paper is not ejected, turn the power off and turn it on again. If the printer fails to eject the paper, contact a Canon Customer Support center for assistance. Other solution here: http://canoncanada.custhelp.com/app/answers/detail/a_id/10212/~/error-messages-displayed-on-the-screen-(selphy-es30) For cleaning try local canon provider.
Dec 12, 2010 | Canon SELPHY ES30 Thermal Photo Printer
Symbol lit up but don't know what symbol means, I don't have manuel - begins with 2 dots :
The symbol with the 2 dots and what looks like a jagged line is the paper jam indicator. Open the paper tray and or front and back access doors to find and remove the paper jam. I the light still does not clear try turning the printer off then on to reset the jam indication.
Aug 20, 2010 | Lexmark E260 Laser Printer
Tomtom 720 won't turn on. Its charging as i type this as am not sure how flat it is. But..... Q1. Left it on charge on laptop for about 45 mins and it started to install Tomtom home. Windows Vista then...
Remove the SD card and try to connect to your computer, the 720 maps are in the internal memory and the unit should start. If not try a hard Reset through the "Reset"hole in the case of the GPS. insert a small paper clip to reset the GPS.
Feb 15, 2010 | Tomtom GO 720 GPS Receiver
Paper stuck in the printer because of dead camera battery
Been there before. There is no easy way to do this however you can call canon and there is a reset switch pattern that will rest the memory in the machine and run a self test at start up this may help
Nov 06, 2009 | Canon Selphy CP400 Thermal Photo Printer
Paper jams - we got copied from mom that passed away - no manual. We don't know what the symbols mean. Trying to score a manual but immediate problem is that paper stops feeding. Error message says there's...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=336&modelid=1936
Unfortunately, I can't direct you where to score a manual either. The jam in this case means that paper did not travel far enough into the copier within the correct amount of time. It is possible to clean the feed roller, (with enough patience) I suggest using IPA (rubbing alcohol). Hope this helps.
Aug 06, 2009 | Canon PC-425 Color Copier
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
Canon pc 720
Check if you have any matter that is blocking the paper path, also try to clean the rollers that picks up paper. If you happened that copier is in a dusty enviroment, dust could deposit on rollers, and rollers when picking up paper will start slipping. Try to clean with alcohol.
Jul 04, 2008 | Office Equipment & Supplies
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
