Close cover hp 2820 lcd message
Thank you dddizon
I clean all the sensor, but the problem persists.
Would you a new solution?
Please help me, I must to fix this unit.
regards
smartcolorin " jh "
  • 97 Answers
Did you check a piece of paper stuck?
Please double check again and close the door properly.
Note: if they have paper jam in your printer or xerox please turn off the machine before you get the paper jam.
Posted on Oct 02, 2008
HP 3030 error message paper jam - clear papaer path. There is no paper in the machine. I have cleared and cleaned the machine, turned it off, waited 30 secondsand turnedit back on and still get the error...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 29, 2011 | HP LaserJet 3030 All-In-One Printer
Hi, I've got an HP Photosmart D7160. It continually says "Paper Jam". Actually the error screen says something like "please remove paper jam and then press OK", but there is no paper...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.get more help and information for hp printer support hope this helps you.
Thanks
Michel
Feb 21, 2011 | HP Photosmart D7160 InkJet Printer
I have an hp colour laserjet 2820 printer and it tells me there is a jam in the paper path. i have taken out every carteridge that I possibly can and opened every door that can possibly open and there is...
this error its tricky. You need to take out the fuser (in the back there are two blue locks) and inside the printer in the center of the paper path you will find a black plastick stick. Its a sensor for the paper path that did not went back to the regular position. Its dificult to explain, but if you can find it the issue will be solved 100% sure
Sep 07, 2010 | HP LaserJet 2820 Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Hp 2820 prints only on right side of page
Yes, you will need to replace the drum unit as well. be sure to shop around so you can get the best price because some people mark up the price for that part. You can check the status of your supplies from the printer itself by pushing the "menu" button the printer and scrolling through until you see something about supplies status then press the check mark button.
Jun 02, 2009 | HP LaserJet 2820 Printer
Back cover open
There is a sensor on the back of the fax machine inside the back door area. There you should see a few plastic chutes that may have a small movable plastic lever called a actuator. This actuatoer may have come out of its pivot points. The parts usually can be snapped back into place. Check by moving the parts and see if the error message goes off. You must move the chute open or closed while looking at the lcd display. This may narrow down your issue.
Feb 13, 2009 | Brother IntelliFax-2820 Laser Fax
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Lcd message close cover hp 2820
Make sure that the door switch actuator is plugged in and that the tab on the door isn't broken or bent.
Oct 07, 2008 | HP LaserJet 2820 Printer
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
59 people viewed this question
jasbo
jasbo
