Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
40 CC WILD THING POULAN
THE CHAINSAW DIED AND WONT START. THE PLUG IS GETTING FIRE THE GAS BULB IS GOOD AND IS GETTING GAS. IT SEEMS LIKE THE KILL SWITCH IS ON OR SOMETHING WILL NOT START JUST DIED
  • srussell Oct 23, 2008
    First i could not keep the saw idling, turned the 2 serrated screws 1/4 turn clockwise and changed the plug. seemed to work fine sometimes would not idele . ran 2 tanks of gas , turned it off, now it won't start . it turns over fine , but nothing at all.
  • 181 Answers
Remove the muffler and see if there are score marks on the piston,if score marks are visable,it needs piston and cylinder.if engine was ran lean this will happen.most people run these machines lean.you will get a flooded look to the spark plug when the piston is scored.............
Posted on Jan 07, 2009
    Problem Solver:
  • 9 Answers
Generally, these saws are set at the factory and aren't supposed to be adjusted. If you can remember how far you turned each screw I would suggest you turn it back to where it was. Turning the screws clockwise leans out the mixture and although it would seem to make it run better warm, it is too lean to start properly. If the engine doesn't start at the factory setting you probably need to take the carb apart and clean it and put a new kit in it.
Posted on Oct 26, 2008
2 Suggested Answers
WeListen2You
  • 538 Answers
SOURCE: 40 CC WILD THING POULAN
maybe the thermal sensor in the engine is overheated..it is inthere to keep the engine from frying.
Posted on Oct 23, 2008
Have a poulan wild thing and the oil bar compartment has gas in it
I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
Oct 28, 2014 | Poulan 18" Wild Thing Chainsaw
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 18in 40 cc WildThing ChainSaw Won't Start.
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Apr 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The spark plug is firing and is getting gas but won't start
It sounds like you have low compression in the engine. I would check the compression it should be 100 psi.
Mar 10, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Poulan 18" Wild Thing Chainsaw. replaced bulb,
Ok lets get the pipes conecterd correctly to start with, the hose comeing from the tank with the filter on the end, connects to the carb fuel inlet nozzel ( the nozzel neares to the pump cover held with one screw ) the pipe coming from the other nozzel on the carb goes to the short nozzel on the primer ( suction ) then the pipe from the longest nozzel on the ptimer goes back to the tank, once you have this correct, try the saw again. Change the filter in the tank, the carb screws will have some type of anti tamper device, this is why you only have a small amount of adjustment, you may need to remove these to adjust the carb properly, if there are any splits or cracks in the fuel lines the saw will not run properly.
Mar 05, 2011 | Poulan Garden
Wild Thing 18" chainsaw model 952-051338 Spark
Spark plug size= 3/4 or 19mm. Champion RCJ--7Y gapped to 0.025.
Fuel mix= synthentic 40:1.
http://www.manualsonline.com/ex/thread/view/idThread/3524133
Sep 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Will not start
first check for spark then check ignition switch and coil and that's a good place to start
May 14, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
My Poulan saw will not fire
Hi
Check if the gas tank cap vent is plugged.Check if the flyweel key is sheared(ignition timing point).Check the fuel filter and air filter.
Hope this helps.
best regards savumihai71
Dec 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
693 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
