Question about Samsung Spinpoint MP0402H 40 GB Hard Drive
Samsung hard drive model number
How do i locate the model number on my samsung hard drive? I'm trying to get the correct jumper settings to make it a slave drive on my system.
  • Melinda Reno Oct 02, 2008
    well there are three seperate labels
    lower 32gb
    upper 32gb and
    the third one i cannot read something like (32gb (clip)
    which one do i set it for?
    Master:
  • 568 Answers
Just remove the jumper from your hard disk drive that will surely solve your problem
Posted on Nov 07, 2008
    Genius:
  • 1,689 Answers
If this is a samsung, on the actual HD, you will see the jumper labels like the one below.
Usually it will say:
M = Master
S = Slave
Cs = Cable select
but if it is not visible anymore and you have 4 sets of pins, then the slave may either be the 3rd or the 2nd if you are looking at it from the back.
if you have other questions just let me know.
Posted on Oct 02, 2008
  • marlon john madrid
    marlon john madrid Oct 02, 2008
    Is this a SATA HDD or an IDE HDD?
Select as master
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Nov 14, 2011 | Samsung (SP0411N) 40 GB Hard Drive
WINDOWS SET UP FAILS TO LOCATE THE HARD DRIVE ACESS SEEMS TO BE DENIED
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Andrew.A
Apr 07, 2011 | Maxtor Hard Drive
Don't know how to set jumpers for master and slave
These jumpers you're referring to normally are spoken of when dealing with a CD/DVD Drive or a hard drive. Usually it's an older one too. They look like this...
You'll need to look on the device itself. There it will have labeled which pin set is for slave or master. Just move the jumper to the correct pins.
Mar 13, 2011 | Computers & Internet
I have a Samsung SP2514N (250GB/7200rpm/8M/PATA) drive that I am trying to use as a USB drive on my laptop with Vista on it. The device manager shows that there is a drive there, but that is all. It does...
If your using an external drive case, the jumper pins should be set at "single". If that doesn't work you can try moving the jumper till the drive shows up, or use no jumper at all. If it still doesn't work after trying all jumper positions or no jumper then the drive could be bad. Make sure to power off the drive before changing the jumper.
Feb 15, 2011 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
My samsung 40 gb hdd not detectin inany computer after new installation
Is your hard drive a SATA (Serial ATA, a thin cable) or IDE (a fat, usually gray cable)?
If your hard drive is a SATA, be sure that the both the power and data cables are securely connected to the hard drive (and data to the motherboard). Then go into your BIOS and make sure your hard drive is seen by the motherboard. It should read a model number similar to that of the model indicated on the hard drive label.
If your hard drive is an IDE, make sure you've selected the CS (cable select) mode on the hard drive using the correct jumper setting. It should be displayed on the label using a small diagram. If it isn't, you can use the Samsung HDD Jumper Settings page to check the settings. Also be sure the cables are secured, as IDE cables can be difficult to fully connect. If this is the case, try using just the hard drive on its own without any other IDE/SATA devices connected, and see if your motherboard detects it.
Try different cables for either type to make sure it's not just the cables that are causing the issue.
If all the above have been tried and your computer still cannot see the hard drive, you may have a faulty hard drive, motherboard or power supply. Try using your hard drive in a different computer, if it still fails to be recognized, you'll need to replace your drive. If it is recognized, your motherboard or power supply may be at fault. Try a different power supply. If that doesn't work your motherboard may be the issue.
Best of luck.
Mar 21, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Maxtor DiamondMax 4R120L0 120GB drives
You have to be make sure you set the "jumpers" on the hdd to the correct locations. Most hdd's are marked with picture that will show the correct jumper settings on them.
Dec 27, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
I need jumper setting for a Maxtor Mode. #
http://search.seagate.com/wwwsearch/www3search.jsp
Try this site, just locate your paticular model number for diagram. Hope this helps.
Aug 17, 2009 | Maxtor Computers & Internet
Samsung TS-H492 Jumper
hai
if u have two seperate data cable to hard disk and dvd rw,there is no big changes to made in jumpers,but u have only one data cable u should select jumper as a master to hard disk and slave to dvd rw,
basic identification to master jumper is that ,it place is close to data cables ,and slave is next pin,in typical models
also u se the detail in hdd and dvd rw's jumper locations
thanks
prasanna
Mar 01, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Samsung Spinpoint MP0402H 40 GB Hard Drive Logo
392 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
