Question about Canon imageRUNNER 400S Copier
E677 In my canon image Runner 400s copier an error (E677) occurs frequently. Our technician told it is problem of printer board. He removed the printer board and sent it for servicing. The same error still occurs when taking photo copy also in fixed interval. Can suggest a permanent solution for this.
    Sniper:
  • 105 Answers
Press the additional * 2+8 additional *
select the copier on the screen
select function
select clear
select ERR
press OK
restart the Copier
Posted on Oct 27, 2008
  • 3 Answers
E677 messages how to solve the e677
Posted on Jul 21, 2012
E677
E677 refers to an error in communication between the printer & image process board, there would be sub codes 0001 through 0006. check for a loose wire or connector between them
see for blown parts on boards fix them or replace them ( the second).
hope i help
Dec 02, 2010 | Canon imageRUNNER 400S Copier
Como solucionar el error e677
E677 IS PDL board mounting error
Mar 05, 2010 | Canon imageRUNNER 400S Copier
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Jun 01, 2009 | Canon imageRUNNER 400S Copier
E677 Error in canon IR400
switch main power off and on E677
Feb 24, 2009 | Canon imageRUNNER 400S Copier
How to remove 4 cassette unit from canon machine IR 400
THIS WILL BE SOFTWARE SETTING ON THE CONTROL PANAL
CANON IMAGE RUNNER 400S COPIER USERS GUIDE
OR
CANON RUNNER 400S SERVICE MANAUL DRIVERS
OR
WWW.CANONUSA.COM/COPIERS
ROD
Feb 09, 2009 | Canon imageRUNNER 400S Copier
Ir400 e677 error
E677 on iR400 is the otional printer board assembly was trouble. It must be change. Try this : replace your optional printer board assembly, the problem was correct? The other day you must bought optional printer board assembly. God Bless You....?!
Feb 06, 2009 | Canon imageRUNNER 400S Copier
CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Sep 11, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
367 people viewed this question
old marine
old marine
