Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Cannot copy DSC02049: The path is too deep. Error message appears. The file is less than 1MB in size. This message appears even when copying from the root directories. It has 490MB available memory. The total capacity is 512MB
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
I am using a software called Long Path Tool for such errors and it is working like charm, i have no problems in copying or extracting anything anywhere.
Posted on Oct 02, 2015
    New Friend:
I got the same message recently and installed "Long Path Tool" program which solved the problem.
Posted on Mar 27, 2015
It seems all USB ports are not equal. Of the ports available, the ones on one side of the computer seem better than the ones on the other side. Changing to a different port solved the problem. There have been no data transfer issues since the change.
Posted on Oct 03, 2008
I cant copy a big file (example: ISO file size 7gb) into my transcend external hard disk 500gb. a pop out message will appeared (File too big to transfer) help me please. Thanks
Please check how many Mb free disk space you currently have on your transcend device as the description of the pop up message sounds like the default error message from the operating system stating that the file you're trying to transfer is too large to fit on the destination drive. Perhaps try copying and pasting a smaller file first just to make sure that there's nothing wrong with the drive before attempting to transfer such a large file.
Apr 12, 2011 | Computers & Internet
I keep getting error -36 like some of my files are corrupted is there anything I can do?
slyda
If you are getting a corrupted data message you can try to run disk cleanup on the drive to see if this fixes the problem.
How to run Check Disk in Windows 7
If this does not fix the problem then you will need to backup your files off the drive and do a full format. If you still have trouble after formatting the drive this is a sign that the drive is failing.
Issken
http://www.fixya.com/users/issken
Jan 13, 2011 | Western Digital My Book Essential 1TB...
Having problem copying two video clips to computer. They are quite long - 20 and 10 mins a piece. Would this necessasrily cause problems? Any advice appreciated.
Well I don't think so that it's because of big video size.
What error you got when try to copy these file to computer?
(Video size metter's when you try to copy these big file to low memory (less memory then file size) hard disk. may be there is no enough space to copy these file on HDD, So please check disk space in your computer before copying files) Post further comments for more help or information........
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Can not copy outlook messages
It looks like your external hard disk in FAT32 system and outlook messages file .PST is more then 4GB.
To know the file system of the Hard Disk right click on the drive select properties.
Check your file system first. FAT32 will not support more than file size of 4GB.
There are 2 options to copy.
1. Split the .PST in to 2 or more outlook data file
or
2. Convert the FAT32 System to NTFS.
To convert from FAT32 to NTFS. go to following link
http://support.microsoft.com/kb/307881
Mar 07, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Error copying file or folder c annot copy xxxxx
try copying the file into a folder with different name
Mar 05, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Western digital my passport 320 file path too deep
The "path" is the full name of a file or a folder, e.g.,
C:\Documents and Settings\User\Local Settings\Temporary Internet Files\Content.IE5
If the path has too many characters, you get the error-message that you reported.
If you can, rename one of the folders, using a shorter name.
Jul 17, 2009 | Western Digital My Book Essential Edition...
Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Jan 27, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Copying dvd into aspire 1 int drive using Sony external DVD write
try to make image of dvd rather than coping...U can do this by nero copy disc option..
Dec 11, 2008 | Acer Aspire One PC Notebook
I cannot copy files
I used to get this problem until i updated my USB drivers. Or try a different USB port. I only have USB 1.1 and this device is 2.0. They should be inter-compatible but you know how these things are sometimes. Make sure the temp of the drive is reasonable too, I've not had heat problems with this one but i have with other external drives in the past.
Hope something I've said helps.
Oct 28, 2008 | Western Digital 250GB MyBook External USB...
I cannot copy iso games
try dragging the files into the folder you want, instead of just copying them. because your psp is recognised as a mass storage device, it will copy the files onto the memory stick when you move it instead of physically moving it like it would if you moved it to a folder on your hard drive. good luck!
Feb 01, 2008 | Sony PlayStation Portable (PSP) Console
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
255 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
