Question about Olympus Cameras
OLYMPUS MJU 300 LENS DOES NOT COME OUT WHEN SLIDE IS OPEN SOMETIMES IT COMES OUT BUT IMMEDIATELY RETRACTS BATTERY IS GOOD
  • lisakarine28 Jan 22, 2009
    the battery is fine i can view pictures on quick view but when i slide door open to take a picture nothing doesnt come on lens doesnt come out absolutly nothing
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Check the screws in the bottom of door or else repair
Posted on Oct 02, 2008
Mju 300 lens barrel will not retract
check the batteries! all features will not work on drained batteries. If the problem is in the hardware, then think about getting a new camera.
Apr 10, 2012 | Olympus MJU 300 Digital Camera
My Olympus Tough 8000 charges up to a blue light but when I unplug the charger and switch it on, it just beeps multiple times and switches straight off. I've only used it for a week and it's a new,...
i have the same problem too. Mine is mju tough 6010 and it just beeps and switch off. The metal cover in front of the lens won't open. Mine is just 1 month old.
Aug 27, 2010 | Olympus Mju Tough 8000 Compact Digital...
The lens will not come out when i slide the cover, it doesnt start although it is fully loaded, whats wrong?
Dear feldt,
There is a mechanical displacement in your camera. So get it serviced....
Actually Digi Cams are very delicate. So even small amount of **** or shock also can caused such type of problems... Or there could be a problem between your Battery mechanism... You can also try be inserting another battery.
May 01, 2010 | Olympus MJU 300 Digital Camera
Camera turns on then immediately turns off
Quick turnoff is normally a symptom of low battery power. Make sure that you have fresh/charged batteries in the camera. If fresh power doesn't solve the problem you will need professional service on the camera.
Bill B.
San Antonio
May 12, 2009 | Olympus Stylus 400 Digital Camera
MJU 300 battery charged .slide open no power
This may be a repair issue with the sensor that is located behind the front sliding lens cover. You may want to call Olympus Customer Service to discuss repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3
Feb 11, 2009 | Olympus MJU 300 Digital Camera
Olympus Mju mini - lens cover will not open
check out first if the battery is fully charged.and if the battery is very old.then prefer replacing the battery instead of charging.and if the battery is new,then the cover of the lens must be getting stuck up so try tapping the device from all the sides it will automatically get opened.also off the camera completely and try to move the lens door manually up and down.sometimes the gear assembly gets stucked and this makes it free to  move.
Nov 29, 2008 | Cameras
Olympus 300 mju
well sometimes that happen, and can be two things 1st the camera got very wet, or the button inside got broken and needs to be replaced.
Feb 09, 2007 | Olympus MJU 300 Digital Camera
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
MJU 300
Ian, It's not a solution I'm afraid, but I have the exact same problem as you had. What's worse, I followed the exact same methodology as you did and now my camera doesn't work either. Unlike you though, I own it, so have nobody to answer to. Wondering how you got on with yours? Did you find a fix, or take it to a repair shop in the end? Sean
Oct 04, 2006 | Olympus MJU 300 Digital Camera
Cameras Logo
117 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
