Question about Watches
I have a new tag watch and can't get the button out to change the time - is there something special I need to do ??
    Champion:
  • 203 Answers
The tag normally has a screw in button turn it anti clock wise it will pop slightly then you pull it gently out some times it moves twice 1 for date 2nd for time . make sure you push it back in and then screw it tight as this is a water seal. if this helps please rate joe
Posted on Nov 22, 2008
I have a brand new watch: Tag Heuer aquaracer automatic calibere 5 model WAN2110 and the date is not advancing (as it should every 24 hours). Any reason why?
You are actually supposed to be using a special case opener for this type of watch, however, if you want to open it, always remember, righty tighty, lefty loosy!
I am pretty sure those watches are water proof up to 3 ATM, so once you open that watch, just know, if you don't get the back put on tight, it's going to leak.
Good luck, i know you can do it. Oh, and if you have ever had the watch in for service before, there are ALYWAYS **** watchmakers who like to over tighten the watch cases. My husband is a watchmaker, and we have seen this hundreds of times. :)
Jul 18, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
Hi, My TAG has been in and out of service three times, the hands came off, the winding mechanism stopped working and the tertiary timing hand has come away this week. I wear it for work [in an office]...
I have this same exact watch with the same problem. In November of this year, my watch just stopped with an inability to autowind itself. I'm a little mad because I have babied this watch, while only wearing it on special occasions (10x). What's the problem?
Nov 21, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
(cj1110.ba0576) Wrist Watch: the second hand on my tag watch is sticking for a ...
you don't have to change battery, as it was still at the right time. There might be some other reason that your watch behave like that. A test on the capacitor of your watch is needed, if this still strong then i suggest you should have your watch General Overhauled by a technician.
May 18, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
Feb 19, 2010 | Tag Heuer F1 Indy 500 CAC111B.BA0850
Second hand moves in 4 second increments
when watch act like this most of the time required new battery
any expert watchmaker well change it ,, and if you are in chicago
we do change battery on tag.
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 23, 2009 | Tag Heuer Kirium (CL1212.BA0705)...
I need to know if I need to purchase a watch winder for my TAGs
Use a winder if you must but I recommend just winding and setting when you want to wear them as most winders I have seen are very cheap and unreliable. Expect up to 50 hours from most watches usually not less than 30, this is if the have recent< 5 years, overhaul.
Jun 11, 2009 | Tag Heuer Link Automatic Chronometer...
My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Feb 09, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Jan 23, 2009 | Tag Heuer Link Automatic Chronometer...
How to remove links on a tag heuer cj1110.ba0576 watch
tag needs a special tool, try a jeweler should only cost 10-15 bucks!
May 10, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Watches Logo
313 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
