Question about Dryers
Dryer when you turn timer it does not click or operate machine
    Genius:
  • 1,122 Answers
Could be the door switch is bad(does it click when you push it in and out?)could be you blow the main fuse inside from cloogged vents on the dryer and wall,also check your power cord going into the dryer if you can(be carefull-SHOCK)let me know what you find and we can go from ther(i don'tthink it's the timer)
Posted on Oct 02, 2008
"timer not working"
All the timers I've ever seen have 2 main parts. One is the electric motor, which is just like an electric clock. The other is a set of controls, usually in the form of a squarish metal box, that the wires fasten to. So far, I think you need to buy a replacement "timer", however the name is a bit misleading, as the timer is actually both pieces together.
I buy my pars from e-bay, after looking up the number on "Sears Parts".
Be blessed.
Jan 09, 2014 | Indesit IS70C Electric Dryer
Maytag lsg7806aa not stopping
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Oct 25, 2008 | Dryers
Tip
What causes my timers to burn out on my washer, dryer and dishwashers
when setting your tmers on your washers, dryers and dishwasher, Do not turn the timer while the machine is in operation. When this happens the timer contacts are arcing and burning. on dishwashers and dryers, Open the door slightly to set the timer. never turn the timers while the machine is in operation. Timers are expensive to replace. If you need to replace a timer, you may consider the cost of a new machine with a warranty. Warranties do not cover timer abuse.
on Jun 08, 2010 | Dishwashers
Dx4500 ge dryer
Maybe the knob is broken and slipping on timer shaft. If not, replace timer.
Sep 10, 2017 | Dryers
Malber WD1000 dryer timer starts running immediately when set, even in the middle of wash cycle
Call in the troops! You need to have the controller panel opened and checked for excessive lint and dirt. There is a short or two in that mess!
Dec 26, 2012 | Malber WD1000 Front Load Washer/Dryer
The timer control knob seems to be free wheeling & no longer clicks when you turn it. We looked at a web site that sells parts & think it might be the timer, does that sound right?
Hi, It has something to do with the timer, that I can tell you.
Some timer knobs must be pushed in to rotate them, Others timer knobs must be pulled out. And, of course, some timers you just turn.
If you can turn the knob and it spins but the pointer on the timer does not spin. It is the knob assembly itself. Possibly just loose.
If you can turn the knob and the pointer on the timer rotates freely without any type of click or resistance, The timer is failed.
If it is the knob, you should be able to pry off the center piece with a very small screwdriver and check to see if the know is loose.
Maytag has used different types of mechanisms in their timers. So good investigation will help in the determination.
If the symptom you are experiencing is that the machine doesn't run. Other things can be the cause of that. An inoperative door switch will render a clothes dryer silent.
I hope this helps,
Good Luck,
Mark
Jan 16, 2011 | Maytag MDG9606 Dryer
Dryer will not start
Dryers are quite simple. Just a timer and a door interlock switch.
The timer tells the machine what to do and for how long.
The door interlock switch tells the machine the door is closed and it is safe to start.
TURN THE BREAKER OFF. DRYERS RUN ON 220V AND WILL KILL YOU IN A HEARTBEAT.
Open the door and look inside the door frame for a pin switch. It should move in and out freely. If it is jammed in it will not start. Pull our with pliers if jammed and gently press in and out a few time to free it up.
Not it?
I don't know which machine you have so I can't tell you the exact location of screws etc so the following is generic.
Open the machine and check for voltage across the door switch. Proper operation of the door switch.
Timer.
Check for voltage at the timer.
Check for voltage at the start switch.
If you have voltage at the timer, door closed. It is the timer that needs to be replaced.
Hope this helps.
Mar 14, 2010 | Dryers
Dryer runs,ignitor is "not" clicking. dryer set to automatic, with about 10 mins left on timer, dryer continued to run untill manually turned off. when re-started ignitor would not ignite
DRYER TIMER WILL NOT ADVANCE UNTIL PROPER TEMP IS REACHED.TRY IT ON TIME CYCLE.DOES IT HEAT ?IF NOT REPLACE THERMAL FUSE AND TSTAT MOUNTED ON BLOWER HOUSING .REMOVE REAR PANEL OF MACHINE TO ACCESS THIS..~COST $35+
Dec 12, 2009 | Kenmore 74612 Gas Dryer
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Dryer won't cycle through settings nor eventually turn off.
The problem is most likely the timer switch. If you call Balcum appliance in Superior WI they should be able to give you a good price on a new or used one.
Thanks,
TIm
May 28, 2009 | Dryers
Dryers Logo
50 people viewed this question
Top Dryers Experts
