SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
SOURCE: Windows Service Pack 1 Problem
Try repairing the startup problem using the bootable disc.
If still it doesnt work try restoring your PC using the bootable disc to the point before installing the service pack.
Else you will have to reinstall the OS.
SOURCE: Laptop was working fine. Yesterday, it shuts down
try this first, on the recovery CD there is an option repair just right before you press the F8(before you perform format) there is a selection that says press F8 to continue or R to repair, if you ss R it will Brin you to a command promt type "fixboot" and hit enter then type "fixmbr" the hit enter again type exit and see if your pc boot normally
SOURCE: I am trying to install Vista on my computer
try hitting ALT f10 while turning on computer it will install factory software
SOURCE: I have an acer laptop. I downloaded service pack
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then defragment your hard drive also
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
dont forget to vote
hope this helps
dont forget to vote
