Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Printer error message appears printhead missing not installed or come loose have done it all over again about 10 times no results
    Problem Solver:
  • 12 Answers
Try to do this, power cycle your printer, turn off, unplug the power cable for 20sec. then plug it back again, try to remove and then reseat your printhead 5 times. make sure that you hear the snapping sound when you insert your printhead into your printer. if it still not work, call tech support of kodak. maybe your printhead is defective.
AIO Tech. Support 1-800-421-6699
Posted on Oct 02, 2008
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Gives message Printhead loose missing or not installed. changed several times same message
If you already replaced Print head then same error occur their might be a problem with the carriage unit. kindly check also if there is a leak inks on a carriage contact then clean it.installed again print head.
May 08, 2015 | Kodak 6150 AllInOne InkJet Printer
Installed new ink cartridges and now repeatedly getting error messages about the printhead being loose or missing - which it isn't. Any ideas?
Take out the cartridges, and close the printer. Then open it again and reinstall the cartridges to see if that solves your problem.
Jun 05, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error message, printhead missing or not installed or has come loose. The printhead is in place, I removed the cartriges and removed the printhead then replaced them with the same results
help! I am looking for the solution! I also have a broken arm and i keep gettin timed out. Error message, printhead missing or not installed or has come loose.The printhead is in place, I removed the cartriges and removed the printhead then replaced them with the same results. I you can respond please instruct me whay to do. i have had my printer out for 10 days. ps, my phone number is 931 993 8269 email is jiyoung@fpunet.com
Dec 23, 2010 | Kodak ESP 5 Printer
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Display says printhead not installed or loose
Make sure when you put it in, you are firmily pushing it towards the back of the printer, until you hear a loud snap. When you put it in the first time, DO NOT put the ink cartridges in. Close the cover and wait until it tells you that the ink cartridges are missing. If it is still telling you that the printhead is missing, it should be replaced. You may contact kodak support @ 1 800 421 6699, and have them help you to replace it, free of charge.
The printhead is not for sale.
IF after replacing the printhead you have the same problem, then is the printer the one that needs replacing.
Dec 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Newly installed and getting error on printhead and ink cartridges
If that error happens every single time you turn on the printer, that pirnthead is faulty.
But if the error only happens some times, try a firmware update from www.kodak.com/go/downloads
Jul 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error message: Printhead missing, not installed correctly or has come loose
In regards to the error message with the printhead missing or come loose......I had that issue just shortly after I installed my printer. I was going crazy trying to fix it taking it out and reinstalling which was a pain, removing the cartridges and then the printhead to no avail. Finally I got smart and disconnected the power cord from the printer itself, not directly from the outlet. Once I did that and turned the printer back on the error was gone. It might have been a fluke, but it worked for me, so you might want to try it.
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
462 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
