Prevent paper abrasion has been set, and I cannot cancel it
  • 2 more comments
  • rmarquez88 Nov 22, 2008
    printer says prevent paper abrasion set, but when i go to the settings it ISNT SET...but keeps saying it IS and the print comes out bad. HELP !
  • Anonymous Mar 10, 2009
    I am getting the same error message and can't reset it. "Prevent paper abrasion is set" The radio buttons on the dialogue are greyed out. It is a printer I purchased used and had it shipped in--a Canon i9900. However my print quality seems OK so far.
  • Anonymous Mar 22, 2009
    Canon Pixma IP6000D PLEASE, PLEASE, PLEASE help me get rid of paper abrasion program.
  • Janet Venceller
    Janet Venceller May 03, 2013
    i dont even know where to find it
2 Suggested Answers
  • 17 Answers
SOURCE: Paper Abrasion
first open the printer option by cliking start -->settings-->printer and fax,right click on canon pixma printer cancel all printings, then off the pring again on it.
Posted on Aug 13, 2009
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
Tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
on Jun 11, 2011 | HEWLETT-PACKARD Hewlett Packard P1102...
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
CDS slipping when playing.
Try the disc in another CD / DVD player.
It is important to make sure that the DVD itself is the problem, and not the CD / DVD player.
Cleaning a CD / DVD player is a much more intricate process that requires device-cleaning hardware.
Lay the disc artwork-side down so that you can easily clean the playing side.
You should always avoid setting a disc playing-side down to prolong its lifespan.
Gently rub the disc with a soft, lint-free cloth to remove all traces of dust and fingerprints. Always rub a disc from the center toward the outer rim in a light motion to prevent any other damage.
Apply a light amount of toothpaste to a cotton wool ball and gently rub the disc from the inside out.
You may need a few drops of water to make the toothpaste spread easily.
Cover the entire surface area of the disc, or at least the area that is scratched.
Toothpaste is a gentle abrasive that works well for fixing simple scratches.
Clean off the toothpaste with the cloth, once again rubbing from the inside of the disc toward the rim.
Try not to push too hard to prevent further damage.
Apply other kinds of light abrasives such as baking soda or glass cleaner if the sound is still distorted.
Remove the solution with the same gentle rubbing technique.
Purchase a disc-cleaning spray from a local video or electronics store.
These sprays are effective in removing any grime from the disc and filling small scratches.
hope this helps
Sep 30, 2012 | Philips Fwm608/12 600W Subwoofer Mini...
Fwm608 CDS slipping when playing
hope this helps
The printer started jamming and shreading up paper. Now the paper is being pulled through at an angle if at all. When there is no paper going through the printer still seems to be going through the...
The following a step by step instructions for the printer issue:
First Set Prevent paper abrasion (Windows)
By using the Prevent paper abrasion function, the space between the print head and paper is increased, preventing print head contact with the paper.
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer maybe damaged. If there is any foreign material, remove it at once.
1. Power the printer off.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. If there is any foreign material, remove it by hand or with tweezers.
3. Open the front cover and confirm that there is not any foreign material in the printer. If there is any foreign material, remove it by hand or with tweezers.
4. Power the printer on and confirm that the printer operate normally.
Removing paper jam:
If the paper tears and a piece remains inside the printer, open the Top Cover and remove it. If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically.
Paper Loaded in the Cassette Jams inside the Printer
(1) Press the POWER button of the printer to turn off the power. Then, open the Rear Cover.
(2) Fold a piece of A4 or Letter-sized plain paper in four, push it in until it hits the jammed paper, then pull out the paper folded in four.
(3) Close the Rear Cover, then press the POWER button of the printer to turn on the power.
Wait until the jammed paper is automatically ejected.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Sep 11, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Paper Abrasion
Aug 13, 2009 | Canon PIXMA MP610 InkJet Printer
Black smudges at the top and bottom of printed photos
I had the same problem, until i went into the maintenence box, click on custom settings and check the prevent paper abrasion, this is designed for thicker paper and stopped it for a week or so, it did come back and so i took the printer back as it was only 4 weeks old.....
Aug 03, 2009 | Canon PIXMA iP1600 Printer
I want to connect via a bluetooth bu20 a canon pixma mp610 printer to a playstation 3. the ps3 recognizes the printer but will not rgister the passcode. I am caught between sony and canon. can you help.
Issue: How do I access / change the bluetooth settings on the printer?
Solution: Change the machine settings (MP610)
Change the machine settings Instructions to change the settings on the machine. Displaying each setting screen
  1. Press the <HOME> (A) button.
  2. Use the Easy-Scroll Wheel (B) or the right / left arrow to select [Settings], then press the <OK> button.
  3. Use the Easy-Scroll Wheel (B) or the right / left arrow to select [Device settings], then press the <OK> button.
  4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select the item to set, then press the <OK> button.
    < 1 > Print settings
    < 2 > Wireless print settings
    < 3 > Bluetooth settings
    < 4 > PictBridge settings
    < 5 > Other settings
    < 6 > Language selection
    < 7 > Reset setting
  5. Use the Easy-Scroll Wheel (B) or the up / down arrow to select the applicable one from the list, then press the <OK> button.
Print settings
< 1 > Prevent paper abrasion
Use this setting only if the print surface becomes smudged.
Note: When continuing to print with this setting, excess ink may smear inside the machine. After printing is completed, return this setting to OFF.
< 2 > Extended copy amount
Select the amount of image that extends off the paper when printing in borderless.
Note: When setting LARGE, more amount of the edges of an image is reduced.
Apr 28, 2008 | Video Game Consoles & Games
2,051 people viewed this question
jasbo
jasbo
