Question about Intel Motherboard
Motherboard can i use 2.2v ram in a GA EP45 DS4P gigabyte mobo which specifies 1.8v
  • devastator Oct 03, 2008
    thanks 4 the info cheers Dave.
  • 33 Answers
Hello!
Yes you can. Any DDRII RAM can function at 1.8v.
Every memory module has profiles written into it, this allows it to function at various speeds and voltages, and 1.8v is the default voltage for DDRII.
Voltages above 1.8v are used for overclocking, to take full advantage of high speed DDRII memory you should manually set the voltage and frequency in your motherboards BIOS (accessed by pressing DEL or F1 during boot), if your motherboard does not have options to set these parameters manualy then your memory will function at the default speed and voltage
Hope this helps!
Posted on Oct 02, 2008
  • Masterrer
    Masterrer Oct 03, 2008
    You're welcome!
Gigabyte ga-ep45-ud3p (REV.1.6) motherboard
If this is a new install, make sure the board is grounded to the base with the standoff post. If you do not tighten your screws or miss these standoff, your system will short and not power up.
Good Luck
C2Solutions
Jul 04, 2010 | Gigabyte GA-EP45-UD3P - Motherboard - ATX...
New system biuild won't boot to bios. Gigabyte GA-Ep45-UD3L Rev 1.0, Zalman CNPS9500, Intel Q8400, G.Skill 1066 2X2GB Memory, Radeon HD 4650 Graphics card,Antec Sonata III case w/ Earthwatts 500W PS. When...
ok well make sure you have the right ram look in the manual and see if it needs to be non error correcting or error correcting (non ecc or ecc) and if it needs to be registerd or unregisterd ram (AKA: bufferd and unbufferd Ram) dont run it very long with no CPU FAN or it will burn and check that fan by pluging it in someware els thats strange cpu fan is always running when mobo is on.
Feb 24, 2010 | Intel Motherboard
Ep45-ud3l dead socket??
Just to make sure go back through and remove everything not needed as a startup boot. Just put one stick of ram and make sure it is seated, nothing extra...just video card if not integrated, mouse and keyboard. tap the key that gets you into the BIOS and make sure that the HDD has been "initialized" prior to trying the first time boot. If it is a new drive, there is a disc for initializing the drive. Good luck
Jan 05, 2010 | Gigabyte GA-EP45-UD3L Motherboard
I just installed a GA-EP45-UD3P and my OS, windows wont boot
May be window 7 is not supported with your hardware.you can check it with win XP.
Oct 15, 2009 | Gigabyte GA-EP45-UD3P - Motherboard - ATX...
Windows will not boot. just set everything up, and everytime windows tries to boot- it BSoD's
Hello Garzaskater3,
Could you please list components used(i.e. Motherboard make and model, CPU, RAM make and amount, etc etc)
Is there a BSOD message and what is it?
Thanks
Jul 10, 2009 | Gigabyte GA-EP45-UD3L Motherboard
Motherboard compatibility
If you want to replace the mobo always compare the cpu-slot and the memory slots.
Tok a fast look on both of the mobos and both supports same cpu, both supports same memosticks though the the one you have supports ddr2 667mgz and the new one you found supports ddr2 1333+mhz. So you can use it but you may have to buy faster memosticks if you want to use the full power of it.
Here is the support site for the new one:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2843
On that site you will also find all the drivers you may need if you buy it
And here is the support site for the mobo you have:
http://www.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ClassValue=Motherboard&ProductID=1960&ProductName=GA-8I945P-G-RH
Now you can compare yourself if you want.
BTW, that GA-EP45-DS3 is a very good mobo
Good luck to you
Please take a moment and rate my help for you
Nic
Feb 18, 2009 | Intel Motherboard
Gigabyte GeForce 9800GTX+ Has bad problem
Make sure you have the latest version of Nvida's graphics drivers installed. You can find them at nvidia.com
Dec 28, 2008 | Computers & Internet
Intel Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
