Question about Pioneer DEX-P9 CD Player
Pioneer DEX-P9 CD Skipping when warm
When i play a cd for a while the unit must be getting warm and begins skipping on track.
Any ideas what the problem is? i heard its a common and fixable fault?
read somewhere it could be the disc clamping assembly?
Looking for a fix
Thanks
SOURCE: how to select differt folders in my mp3 cd fro pioneer player
Try going to the Pioneer website and find the DEH-p3900mp page. Click on the documents tab and click on owner's manual.
Posted on Dec 28, 2007
SOURCE: pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
tech48
  • 624 Answers
SOURCE: cD skipping with the bass
Has it always done this, or is this a new problem? If this is a new problem you may need the unit serviced. It may need the lens cleaned, or laser replaced. If the laser is getting weaker it can do that. They also have these small oil filled dampers used like shock absorbers. If one of those is torn and has leaked a little oil out it will skip much easier. They also use springs to support the cd mech, if a spring has streched out or come loose, that can also make it skip on big bass hits.
You can always try putting some foam or something around the radio to help keep those heavy bass hits from vibrating the radio. But then the radio may get too hot.
Make sure the radio is very secure in the dash.
If this problem has been going on since you installed the radio, you have an installation problem. The radio is a little loose and prone to move around a little.
Posted on Jun 17, 2008
djproaudio
  • 515 Answers
SOURCE: cdj 800 keeps skipping
Does it keep skipping, or does it keep looping? 2 very different things. If it's skipping, it will sound like it's scratched, and will only skip on some CDs, and not others - unless your tray is messed up.
- Davis
DJ Pro Audio
www.djproaudio.com
www.djprolab.com
www.1200s.com
Posted on Jul 26, 2008
SOURCE: CD's are skipping when playing
Sounds like the laser lens is dirty or out of focus. You can take it apart and try cleaning the lens with a soft cloth and see it that works. If the focus is out of adjustment, that takes alot of patience and time. Never look directly at the laser with the case open. On the bottom or side of the laser lens, there are two small box looking gadgets about 1/4" square with tiny screw type adjusters in the center of them. These are potentiometers, they can develop dirty or burned spots over a period of time. Turning them slightly can give you better performance. If I remember right, one of the pots is for width and the other for height of the laser focus. You can identify them by the small ribbon cables that run to them. Try a very small turn on one and try playing the dvd. Mark with a marker a straight line across the pot and board to know where you started, believe me it helps. This can take quite a while and may or may not work. I find this to be the biggest fault with most dvd and cd players. I have fixed many this way. By the way, I use a jewelers screwdriver. They have small plastic ones for these, but they are hard to come by. Good luck.
Posted on Dec 17, 2008
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
Mar 14, 2013 | Audio Players & Recorders
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
Every CD skips. Seems to skip very badly at the beginning of each track and then about a third of the way through it will play normally. I have put the CD's in the correct way and have cleaned the dust...
The dust has probably got on the lens, which needs to be cleaned too. You can try a lens cleaning disc. But if that doesn't work I would use some Servisol Video 40 on it.
Jul 11, 2017 | Sony CDP-CX450 400-Disc CD Changer
Hi Skipping problem with a NAD C545BEE, plays OK for 1 minute, then skips randomly wthin the track, then will skip to different tracks on the CD, like fast forwarding. No problems with the disc themselves
hi
There is a diode in the power supply which gives dc supply to the laser focusing coil driver ic . if the diode get faulty this problem can occur. Just replace all the rectifier diodes in the power supply stage. Its better than searching for the exact one. then check the cd player is it skips the tracks. if then also its skips the tracks then you have to change the laser pickup unit.
ok
May 19, 2011 | NAD C545BEE
Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Jul 05, 2009 | Audio Players & Recorders
Static and skipping
You might need to have it professionally cleaned / diagnosed. The problem might not be a dirty reader, but a misaligned tray. Many trays, over time, become misaligned. Some more than others. Depends on your use and abuse of the unit. The issues generally happen towards the end of the tracks.
- OPTiC
DJ Pro Lab
1200s.com
Apr 21, 2008 | Technics SL-DZ1200 CD Player
Cd track skidding
This can be the first sign that the optics are starting to fail. It can also indicate dirty optics. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Also, with a dry cotton swab, clean off the "sled rails". These are the shiny rods that the optic assembly rides on. Sometimes the grease on these rails can collect dirt and cause the movement of the optics assembly to be erratic. Let us know how you make out.
Dan
Apr 11, 2008 | Audio Players & Recorders
RS2635 5 disk changer skipping
your cdplayer is probably at intro
Aug 05, 2007 | RCA RS2635 CD Shelf System
HELP!!! My cd player just skips through all song never playing....
Sorry but this unit has a problem with the tracking servo. The problem could be an alighnment, or a bad componet such as the laser assembly, tracking motor or tracking driver IC, with all of these problems the unit will need to come out of the vehicle. Good Luck
Apr 03, 2007 | Blaupunkt Chicago IVDM-7002 Car DVD Player
Pioneer DEX-P9 CD Player Logo
53 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
