Question about Lexmark Office Equipment & Supplies
I have purchased an X2650 Printer/Scanner and cannot get the CD program to "finish" the installation. When I arrive at the connect your printer to the USB port I plug into the same slot that my previous Lexmark 1300 printer plugged into but the CD "continue" option will not let me finish the insallation. The "pop=up" info I get is that the CD does not have any driver for my computer. I note that the "old" printer was plugged into LPT1 wheras the new printer wants a USB port which I do not seem to have.. Can you advise ASAP
  • 10,594 Answers
Please download latest driver for your Lexmark X2650 driver form Lexmark Support according to your Windows like XP or Vista.
Posted on Oct 02, 2008
  • Lexmark Master
  • 19,396 Answers
You need to download and install drivers , if disk is not working.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthe file,doubleclick on the file, if you get introubles ,thenfollowinstructions below to reset and reinstall:
  • Unplug printer .
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
  • Ginko
    Ginko Oct 02, 2008
    Note, on the setup software you have to change a settings if you want to install the printer on LPT port.
  • Lexmark Master
  • 13,433 Answers
Please get the latest software from www.lexmark.com and remove the old ones. Hold on pictures coming below.
  • Ekse Oct 02, 2008
    You will then get the downloads, download the latest driver available. install the driver - plug in the usb when asked.
  • Ekse Oct 02, 2008
    Before installing new software, make sure you have removed and unpluged the old printers.
    start -> control panel -> add or remove programs can be used to easyly remove the lexmark programs.
I download hp 5590 drivers from hp.com i tried to install it, the proces eend normaly, but if i connect the scanner, windows xp show the new hp connect like its not installed yet. I check at add remove...
FIRST UNINSTALL YOUR PRINTER COMPLETELY
REMOVE ALL CABLES OF PRINTER (USB)
REBOOT YOUR SYSTEM
HAVE DRIVER CD
PUT IT IN ROM(CD/DVD)
INSTALL PRINTER SOFTWARE
DONOT PLUG THE USB CABLE UNLESS & UNTILL PROMPTED
PLUG USB WHEN ASKED
FINISH INSTALLING PRINTER
NOW YOU CAN FIND THE SCANNER
Feb 15, 2011 | HP Scanjet 5590 Flatbed Scanner
Lexmark X2650 scanner in Mac OSX 10.6.2 (Snow Leopard)
You need to update your driver by getting the latest software in the Lexmark website here. During software update what usually gets updated are the basic functionalities. In this case it looks like the scanner is not being updated as well. Hope this helps.
Mar 16, 2010 | Lexmark X2650 All-In-One InkJet Printer
My lexmark x2650 printer wont let me scan. ive installed and uninstalled software. i get flashing lights on the top of the printer at the bottom right hand side
Please open the paint from "start/all programs/accessories/paint"
when you open the paint " click on file and selct the option scanner and camer wizard if your scanner is installed then the option is hilichted. click on scan and it will scan the document. this is easiest way to scan the document.
Nov 02, 2009 | Lexmark X2650 All-In-One InkJet Printer
How to install a printer in my laptop without a cd?
Brows to  http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=194:1:0:0:0:0
start typing 2650 into the "Search by Model" inputbox then it should show Lexmark X2650. Then you will get links to download the drivers (XP/Vista/Mac OS X 10.5)
Jun 23, 2009 | Lexmark X2650 All-In-One InkJet Printer
I can't use the scanner or printer on my machine
connect your printer to your computer using USB cable. it is provided with the printer.
check for the driver cd. probably got it with printer. when you put the cd in cdrom drive it will auto run an install program. select the install driver option or similar one suggesting to install the drivers for your printer.
make sure that during installation ur printer is ON and connected to your computer.
new install window will pop up. just do next till finish button appears.
thats it ....... restart your computer and u can use it directly
Mar 18, 2009 | Panasonic KX-FLB801 All-In-One Laser...
I want to install my lexmark printer X2650 ON my vista (sansui
hi
To install driver u need the cd..if u dont have the cd...download vista compatible driver from www.lexmark.com .Connect USb cable to computer...make sure printer is powered on..install driver(either by cd or downloaded driver)
good luck
Jan 25, 2009 | Lexmark X63 InkJet Printer
Error on newly installed printer.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Lexmark X2650 All-In-One InkJet Printer
Need help using x2650 scanner
Lexmark X2650 printer instructions for using scanner
Nov 07, 2008 | Office Equipment & Supplies
Scanner does not work
First make sure that the scanner drivers and all the PSC drivers have been installed.
Or try to reinstall the printer drivers by removing all Hewlett Packard's applications from "add - remove programs" in the control panel. Then disconnect your printer and restart the computer.
When the PC finishes loading windows, insert the HP printer software CD while pressing SHIFT on the keyboard for 30 seconds. Connect the printer again and follow the "Found new hardware" wizard instructions. When a gray sandglass pops up, choose "Decline" or "Not agree" to the license terms and continue with the installation.
After that, try to scan again from Photoshop or another scanning program. Remember that in the reinstallation, you haven't installed the HP image zone software.
May 04, 2008 | HP PSC 950 All-In-One InkJet Printer
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
