Question about Xerox Office Equipment & Supplies
Xerox Workcentre 24. 20 months old. The sreen simply says: Fault/Error, then below: A fault has occured. Switch the machine Off and then On. If the problem persists, call for service. In the bottom left hand corner of the screen it has: 116-321. We purchased the machine second hand when we have contacted Xerox agents they just want to sell us a new machine!
    President:
  • 2,072 Answers
That is a software processing error.
Do you have it set up as a printer? If so, try removing the print cable and power it on that way.
If that doesn't work, you need to have the firmware reloaded. That can only be done from a laptop with Xerox software on it.
Posted on Oct 03, 2008
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Mar 07, 2016 | Xerox Office Equipment & Supplies
HOW DO I CLEAR FAULT CODE 010-313 ON XEROX WORKCENTRE 133 COPIER - Printers & Copiers
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
  1. Press the power switch to the OFF (O) position.
    NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storing files and preparing for shutdown. The machine then shuts down completely.
  2. Press the power switch to the ON position.
Tired of struggling with your old device?
We offer virtual printer support as well as onsite support.
We can help you nationwide!
I am a help desk analyst with MRC and I look forward to solving all of your issues!
Click link below for more information on MRC:
MRC provides total office solutions and service of copiers in California
Oct 23, 2015 | Xerox Office Equipment & Supplies
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
Erroe/fault 093-311
fault Code 093-311: Rotary Assembly Failure Solution : Power the Machine Off and On CAUTION: Wait at least 60 seconds between powering the machine off and then on again; otherwise, damage to the machine and the hard drive may occur.
  1. Press the power switch to the [O] (off) position.
    NOTE: The machine will remain on for approximately 10 seconds while storing files and preparing for shutdown, and then will power off completely.
  2. Wait 60 seconds, and then press the power switch to the ['] (on) position.
Jun 26, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
How to fix fault 116-365 of wc 5330
Solutions for : Fault Code 116-365: An Internal Shutdown Occurred After an SPL Processing Error Related Fault Code: 116-365 Solutions ranked by relevance:
  1. Delete All Jobs From the Job Queue
  2. WorkCentre 5325/5330/5335: Power the Printer Off and On
May 27, 2014 | Xerox Office Equipment & Supplies
Fault error occurred no. 123-333
I install xerox new machine when turn on gives error code 123-333
Jun 20, 2013 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Upon booting I get this error, A fault has Occurred. Some features may not be available. No error code to go on...Xerox Workcentre M24 Now were not able to select any functions on the touchpad, and we...
Sounds to me like you need a drum or one of the other routine maintenance items.
The way to find out is to press your machine status button, then look under supplies. You will probably find that a drum life has expired, the IBT cleaning roll or fuser life have expired.
I am sure if you look there one of those "supply" items has reached its end of life.
In the same area under the machine status , there is also a section there for active messages and fault codes. Make sure you look there. If you have additional questions please ask.
If there is an active message or fault code, e-mail me at rak458@aol.com. Just put Xerox M24 in the subject line please.
Feb 24, 2010 | Xerox WorkCentre M-24 Color Copier
I have xerox wc 7228, when i try to copy it is showing ''A fault has occurred press C botton to cancel '' error 009-936
hello
here is the link Xerox offical site about error codes and things that you can do . i hope it useless.
Feb 10, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
390 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
