Question about GE JBP65 Electric Kitchen Range
Neff oven b1432 is overheating wildly. can't control temperature and this has come about as the control knobs on front panel have perhaps melted! and become difficult to use. Would like to rescue an repair this oven as cheaply as possible. help please
    Novelist:
  • 163 Answers
The only way to confirm it is to disconnect the broil element and insulate the wires, then do some cooking. it will not heat up as quickly or as evenly, but should let you know for sure if it is the broil relay. on that model you can only replace the whole board so if disconnecting the broil allows it to work then you need a new board, if not I have had some units where the oven sensor had bad wire connections at the wiring harness and would only sometimes act up. When I see that I normally just cust out the harness plug and wire nut the oven probe in. (bad connection at the oven probe not at the control board). Be sure to use it long enough that there is no question before replacing board.
Posted on Jan 01, 2009
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
Tip
Common heating faults with Neff B1432 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1432 Single circotherm plus Electric...
HOW DO YOU REMOVE CONTROL KNOBS TO REPLACE THE ON THE NEFF B1451 OVEN
I have a Neff B1451 oven and have removed the thermostat knob just by pulling and wiggling it. Thats all you do. If then you want to rpelace the thermostat, there are two screws holding the unit onto the oven which are accessed by taking the silver metal shrouds off first.
Jun 24, 2011 | Neff B1432 Single circotherm plus Electric...
B1432 door gasket wanted with rounded corners
I believe this is the oven door seal. You can purchase this online from Ransomespares.co.uk product code RS46105 cost £29.25. Easy to fit, each rounded corner has little metal hooks which fit into the pre-drilled hole on the oven itself, simply unhook the old one and replace with the new, simple.
Jun 20, 2011 | Neff B1432 Single circotherm plus Electric...
I need to remove the control panel to replace the Function Selector (knob) how do I remove the panel? Thanks
HI
you dont need to remove panel to replace, it literally just pulls out from the front as a complete assembly you may find using the edge of a teaspoon helps to draw it forward without marking the steel use the curved bowl of the spoon against the steel.
if the knob is damaged from heat escaping (melted) make sure you grill with the door closed.
Feb 22, 2011 | Neff B1421 Electric Single Oven
Hi there, Neff B1432 was working perfectly this afternoon, but this evening when cooking 2 racks of lamb it wouldn't heat up higher than 50 degrees. Sounds like the thermostat...is this an easy job to...
Could be a faulty thermostat, but I would check that element is getting hot before commiting to replace the thermostat.
Run it for a few minutes and feel to see if you can feel hot air blowing from fan at rear of oven. If no heat present, thei it will be the elemnt that is faulty.
Jan 06, 2011 | Neff B1432 Single circotherm plus Electric...
Neff B1432 Oven Not Heating; oven light flickering
If the fan is working o/k then you need a new element fitting.
Remove the panel at the rear of the oven, there you will see the element, remove the fixing screws and ease the element forward,taking care not to lose the wires, disconnect the leads and fit new element.
The light flickering is probably the bulb not screwed in propely or a bad contact, nothing to worry about.
Plz rate my solution.
Thanks
Dec 19, 2008 | Neff B1432 Single circotherm plus Electric...
Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Nov 28, 2008 | Neff B1432 Single circotherm plus Electric...
Neff b1432 electric oven not
I have the same problem too but mine doesn't produce any heat at all. When it's switched on, the air that comes out of it is cool. How could i fix this? Do i have to replace a part or could it be an electrical fault?
May 02, 2008 | Kitchen Ranges
GE JBP65 Electric Kitchen Range Logo
124 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
