Question about Acer Aspire T310 PC Desktop
Hard drive dont load up properly
Switch on,fans go on then,cd dvd combo clicks in, then hdd clicks in but do keep running
    Problem Solver:
  • 47 Answers
Your hard drive is dead mate. sorry. they die form time to time.
buy yourself a new hard drive and an external hard drive caddy (a 3.5" one) make sure the caddy is the right connection for your old hard drive. either sata or ide.
then put the new hard drive into your pc to take the place of your old one, and load windows onto it.
next get your old hard drive into the usb haddy drive caddy/enclosure, connect it all up and see if you can use the ghost function on norton anti-virus secruity to bring back your old data.
hope this helps.
kev
Posted on Oct 02, 2008
Sony DVD ROM will not open, light comes on and tries to open but will not. Other DVD works fine. What with the Sony DVD?
try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
Apr 24, 2010 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
If i put in a cd, it doesnt load or install or anything. nothing comes up. can you please help?
Please check if the CD/DVD driver is installed properly:
To check:
1. Click Start - Right-click My Computer Choose Properties
2. Click Hardware then Device manager
3. Check if there is a yellow question mark on CD/DVD
If Yes - Reinstall CD/DVD using WINDOWS UPDATE
Alternative:
1. Try to check for loose connection between your IDE cable and IDE Socket
2. Check if the 12V Cord from the Power supply is properly connected to device
3. Check MASTER or SLAVE setting:
Normally the IDE Hard disk will be your PRIMARY and the CD/DVD will be your secondary/slave -----
MORE DETAILS ARE DESCRIBE THOROUGHLY IN THIS SITE:
http://www.ehow.com/video_4444761_setting-pins-cd_dvd-hard-drives.html
Please Rate. Thanks.Cheers!
Apr 22, 2010 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
My cd drive shows empty even with disc inserted
If the disks you insert DO work on some other computer,
then it's time to spend $40 and buy a new CD/DVD-writer,
to replace the "dead" unit.
The "working properly" part is ONLY an indication that the hardware has been detected, and the correct software device-drivers have been loaded; it makes no guarantee that the unit will work.
Compare it to having a car -- it looks like a car, but if won't start, it still is a car, although it cannot be used as a car.
Dec 29, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Can't reboot Compaq/Presario desktop, (power supply is working)
If the system recovery disk doesn't work it usually mans that the hard drive is bad. I would change the hard drive and use the system recovery disk on it after replacement.
Dec 27, 2008 | Computers & Internet
Removing the hdd in my toshiba 1135-s125
OK, This is a big undertaking if you are completely new.
1st, if you can get a static guard wrist band - great!
2nd You will be dealing with plenty of screws so keep track
In Toshiba notebooks most screws are marked. Here are some examples:
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
I have .a Toshiba Satellite 1135-S155. It should be a similar configuration, same family/1135-S1xx series.
You will have to remove a total of 9 Phillips screws.
Place the underside of the PC up.
Disconnect all power, cables and Battery from Laptop
The first screw is located just under the Toshiba Serial Number / Bar codes, just above where the DVD/CD-ROM combo drive is located.
Mine is labeled (F5). Unscrew it and place in a safe place.
Pull DVD/CD-ROM combo drive out it is an assembly.
The Hard Drive is located under the DVD/CD-ROM combo drive.
The Hard Disk Drive (HDD) is enclosed within a caddy containing the remaining eight screws.
There are four screws holding the caddy rails to the Laptop and four screws holding the rails, caddy and Hard Drive as an assembly.
Unscrew and place in a safe place/ container they are small. Disassemble the HDD from caddy assembly; place your HD in the caddy and reassembly.
Here is another Toshiba HDD access that is slightly more
straightforward than my 1135 series
So you get an idea of where a HDD is visually:
Above is a photo of the Battery sliding out
Below is the Hard Drive Removal
I hope this gives you an idea of how to go about it for your
particular Laptop
If you need further assistance, let me know
Feb 21, 2008 | Toshiba Satellite 1135-S125 Notebook
DVD combo drive not working
Did you set your jumpers correctly? How about using a different power Cable? Different Data Cable? If all fails try diagnosing the problem. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps
Sep 22, 2007 | Samsung SD 616E (729507925578) Internal...
CD's in drive do not load
Buy a CD/DVD cleaning disc. Try that. Maybe the read head is dirty.
Aug 29, 2007 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
Won't function
Firstly it sounds as if the drivers aren't loading properly, right click on your drive (right click my computer> properties> hardware> device manager). Look for your external drive, rightclick and click update driver and force it to look in your cd for driver files. Secondly make sure you are connecting to a USB2 port, as it may not recognise the hardrive.
Oct 25, 2006 | Plumax PM-350U2-PCS V4 Silver Slim USB 2.0...
Acer Aspire T310 PC Desktop Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
