Question about Refrigerators
Freezer is over producing. Front of drawers and inside of door totally covered in white frost. Can not even open top drawer.
    Problem Solver:
  • 3 Answers
Check that the door seal is good, otherwise it will work overtime to cool itself and produce ice. Otherwise, your thermostat may be faulty.
Posted on Oct 02, 2008
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Samsung RL38SCSW Fridge Freezer not Cooling
Sounds like an air leak around a door seal or the ice maker chute door is open causing frost buildup on evaporator and everything inside the freezer. You also may have a defrost drain line blockage
Jan 07, 2016 | Samsung RL38SCSW (113 cu ft
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
I have the freezer set at 3. There is ice forming all around the door and snow like frost on the food.
Frost buildup on food and ice around the door is due to warm air infiltration. This sounds like a door closure problem. Be sure that nothing is interfering with the drawer as it closes. Be sure to open the upper door and look down at the drawer top to see that the gasket is hitting the steel frame of the cabinet. Look all the way around the entire drawer front checking the seal.
Also open the drawer and hold it as it closes, so that if there is any food product binding it you will see it get hung open.
Good luck.
Jun 13, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 28, 2009 | Refrigerators
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
