Question about NetGear WGT624 Wireless Router
Wps button on the netgear wgt624 - NetGear WGT624 Wireless Router
3 Suggested Answers
SOURCE:
SOURCE: about 108 mbps wireless router wgt624 netgear
HOW CAN I INSTALL MY NETGEARN 108Mbps WIRELESS FIREWALL ROUTER WGT624 v2.
Posted on Feb 16, 2009
SOURCE: not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Posted on Nov 20, 2011
Why did the router ID change when I linked it via the Wps button to the DSTV wifi gadget ?
Here's and excerpt from the Netgear WNR2000 user manual explaining that this is normal behavior for Netgear routers that support WPS..:
  • Keep Existing Wireless Settings. This check box is automatically selected after WPS is enabled to prevent unwanted settings changes, and is also selected if you have already specified wireless security settings or your SSID without using WPS. When this check box is not selected, adding a new wireless client using the push button or the Add WPS Client screen (see "Push Button Configuration" on page 2-14) changes the router's SSID and security passphrase. You might need to clear it if you are using certain registrars, such as for a Windows Vista PC, to configure the router through WPS.
Even if your router is not a WNR2000, it is likely that the configuration interface pretty much the same so you might be helped by looking at Chapter 2 page 17 in the WNR2000 manual here..:
Or else, go to Netgear support (NETGEAR Support Welcome), select Wi-Fi routers and download/display the user manual pdf and search it for "disable router's pin" or "keep existing wireless settings" and verify/change the setting so the router doesn't make changes when you use the WPS button.
May 20, 2016 | NetGear Computers & Internet
Where is the WPS button on a netgear wireless router?
Not all routers have such a button.
Follow the instructions that came with the printer to "manually" select your wireless network, and to enter the password for your network.
Mar 08, 2015 | NetGear Computers & Internet
Locate WPS button on FWAG114
Thanks for posting to Fixya!
According to the manual I found at the following link;
http://downloadcenter.netgear.com/en/product/FWAG114
www.youtube.com/watch?v=8ffqvIoxcOc
WPS is not supported on this router. However, my suggestion would be to reset the WN2500 to default with the reset and start fresh, using the manual setup. You can find the help you need here;
http://kb.netgear.com/app/answers/detail/a_id/19887
NETGEAR Support Answer WN2500RP FAQ
I hope this helps you with your setup!
Oct 05, 2014 | NetGear Computers & Internet
How do I find wps button on Netgear WNR834B
The Netgear WNR834B does not support WiFi Protected Setup (WPS).
You can follow the documentation in the manual to setup WPA-PSK (Pre-Shared Key) and use the key to add devices to your wireless network.
Manual: http://documentation.netgear.com/wnr834b/enu/202-10171-01/pdfs/FullManual.pdf
Jun 24, 2014 | Arris SURFboard SBG900 Wireless Router...
Power not going to netgear wgt624 router
Your power adaptor is very likely the problem. You can get a suitable 12V Netgear WGT624 power adaptor here, for the UK: https://www.digidave.co.uk/jshop/product.php?xProd=360
Feb 20, 2011 | NetGear WGT624 Wireless Router
Dont know how to install a password so other wireless computers cant log on I have a netgear WGT624
Hi dude check this would be useful
http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Things You'll Need:
  • Ethernet cable
  • Cable or DSL modem
  • WGT624 Installation CD
  1. 1 Plug the Netgear WGT624's AC adapter into a wall outlet. Plug an Ethernet cable into the yellow Ethernet port on the back of the Netgear router. Attach the other end of the cable to the Ethernet port on the back of your modem.
  2. 2 Insert the installation CD that was included with the Netgear WGT624 into your computer's disc drive. Click the language option you want to use and then click "Setup."
  3. 3 Follow the setup wizard's onscreen instructions and then click "Finish." The wizard will automatically detect your Internet settings. Open a web browser and navigate to "http://192.168.1.1."
  4. 4 Type "admin" in the Netgear's "User Name" text box and then enter "Password" in the text box labeled "Password." Click "OK."
  5. 5 Click "Yes" and wait for the latest firmware upgrade to install. Double-click the upgrade file and follow the onscreen instructions to install the upgrade.
  6. 6 Click the "Wireless Settings" link if you want to password protect your wireless network. Click the "WEP" radio button and then type in the password you want to use for your network in the "Passphrase" text box.
  7. 7 Click "Apply" and then close the web browser.
Sep 27, 2010 | NetGear WGT624 Wireless Router
I lost wireless connection on my router and I reset the button in back and now I have to configure it. How can I configure it?
Hi
Please check this link. I hope this will you to configure the wireless router..
If any queries please revert..
http://aramki.wordpress.com/2007/04/23/configuring-netgears-wgt624-wireless-router/
Jan 23, 2010 | NetGear WGT624 Wireless Router
Netgear wgt624 won't update settings
update the routers firmware http://kb.netgear.com/app/products/family/a_id/1297
Mar 21, 2009 | NetGear WGT624 Wireless Router
About 108 mbps wireless router wgt624 netgear
Jan 23, 2009 | NetGear CG814M Wireless Cable Modem...
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
826 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
