Question about Dryers
Change belt simpson eziloader 6 kg
Having problem with belt placement on pulley
3 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: changing a belt on a simpson dryer
on what ever side ot the belt it cause's more tention thank you for useing fixya rate me
Posted on Mar 31, 2009
SOURCE: I'm having a problem re-fitting the drive belt to
After some mild swearing, I made sure that I had the belt around the drum aligned (in the same plane) as closely as I could with the drive pulley and tensioning wheel. I think this was partially achieved by placing the belt as close to that position as possible before lining up the front end of the drum with the cabinet opening, and then turning the drum from the front (through the open door) very slowly clockwise (the direction of its normal rotation) to give the belt "time" to align itself fully with the smaller pulleys. A short prayer and a few minutes later, the machine was humming away with all parts playing their "part" in beautiful harmony - without the dreaded sound of a thin black drive belt cluncking to the floor of the metal cabinet.
Cheers,
Andy B.
Posted on May 02, 2009
Hi, my 6 month old Simpson 5kg Eziloader dryer blew a fuse today. Have plugged it into a different power plug and now its not working and making a humming noise. Any suggestions?
have a service technician come and look the start/run capacitor for the motor
blowing a fuse then humming indicates a capacitator problem
Jul 07, 2015 | Dryers
We have put a new belt and bearing on my 4kg Simpson eziloader dryer and spring is in place it works for a while and then the belt comes off again what could the problem be
I would check the pulley on the motor, and the belt tensioner that the belt winds through. My initial thought is that when installing the belt onto the tensioner it may have been bent. GOOD LUCK FRIEND.
Nov 16, 2014 | Dryers
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
If the faint noise is the motor running, the belt is broken.
Jan 03, 2014 | Dryers
Need to know timing marks
REMOVAL
1. Disconnect negative battery cable.
2. Loosen power steering lock bolts and nuts accordingly and remove tension from power steering (P/S) and/or air conditioning (A/C) compressor drive belt.
3. Remove P/S and/or A/C drive belt.
4. Loosen generator mounting bolts and adjusting bolt.
5. Remove generator bolts.
6. Remove water pump pulley.
7. Remove crankshaft pulley.
8. Remove upper and lower timing belt covers.
9. Turn crankshaft so that timing mark on timing belt pulley is aligned with timing mark on engine.
10. Check that "I" mark on intake camshaft pulley is aligned with mark on seal plate and "E" mark on exhaust camshaft pulley is aligned with mark on seal plate.
Do not move camshaft or crankshaft once timing marks have been correctly positioned.
11. Loosen tensioner pulley lock bolt.
12. Protect timing belt with a rag.
13. Remove tensioner pulley.
14. Remove timing belt. Mark the direction of timing belt rotation (on the timing belt) for proper reinstallation.
INSTALLATION
1. Install tensioner pulley. Replace tensioner spring whenever timing belt is replaced.
2. Pull tensioner pulley to its furthest point and tighten lock bolt.
3. Check that timing mark on timing belt pulley is aligned with timing mark on engine.
4. Check that "I" mark on intake camshaft pulley is aligned with mark on seal plate and "E" mark on exhaust camshaft pulley is aligned with mark on seal plate.
If existing timing belt is being reused, install belt in proper rotation direction marked prior to removal.
5. Install timing belt onto timing belt pulley first, then idler pulley, exhaust camshaft pulley, intake camshaft pulley, and tensioner pulley in that order.
6. Check that there is no looseness in belt between idler pulley and exhaust camshaft pulley or between intake and exhaust camshaft pulleys.
7. Loosen tensioner pulley lock bolt and allow tensioner spring to apply tension to timing belt.
Do not add additional tension.
8. Tighten tensioner pulley lock bolt to specified torque.
Tightening torque:28~38 lb-ft (38~51 N·m, 3.9~5.2 kg-m)
9. Rotate crankshaft two full revolutions (clockwise only) and align timing mark on timing belt pulley with timing mark on engine block.
10. Check that "I" mark on intake camshaft pulley and "E" mark on exhaust camshaft pulley are aligned with marks on seal plate.
11. If they are not aligned, remove timing belt and start process from tensioner installation.
12. Measure timing belt deflection by applying moderate pressure midway between camshaft pulleys. If deflection is not correct, repeat from tensioner installation.
Deflection pressure:22 Ib. (98 N, 10 kg)Deflection:0.39~0.50 in. (11~13 mm)
13. Install lower and upper timing belt covers in that order.
Tightening torque:5.8~8.0 Ib-ft (7.9~10.7 N·m, 0.8~1.1 kg-m)
14. Install timing belt guide plate and crankshaft pulley.
Tightening torque:9.0~12.6 lb-ft (12.3~17.2 N·m, 1.3~1.8 kg-m)
15. Install water pump pulley.
16. Install generator belt and adjust the tension.
17. Install P/S and/or A/C drive belt and adjust the tension.
18. Connect negative battery cable.
INSPECTION
Never forcefully twist, turn inside out or bend timing belt. Do not allow oil or grease to come in contact with timing belt.
1. Replace timing belt if it is contaminated with oil or grease.
2. Check timing belt for uneven wear, fraying, peeling, cracking and hardening. Replace timing belt as necessary.
3. Bend timing belt into a "U" shape as shown in figure. Distance "A" must be at least 1.0 in (25 mm).
4. Inspect both idler pulley and tensioner pulley for uneven wear and smooth bearing operation.
5. Inspect camshaft pulleys and timing belt pulley for broken teeth or damage.
Replace any component that shows damage, excessive wear, or that appears prone to a possible failure.
Feb 26, 2011 | 2002 Kia Spectra
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
The Timing belt
Recommended by kia is 100,000 km.
Timing Belt: Service and Repair
TIMING BELT
COMPONENT
REMOVAL
2. Loosen power steering lock bolts and nuts accordingly and remove tension from Power Steering (P/S) and/or Air Conditioning (A/C) compressor
drive belt.
7. Remove crankshaft pulley and timing belt guide plate.
10. Check that "I" mark on intake camshaft pulley is aligned with mark on cylinder head cover and "E" mark on exhaust camshaft pulley is aligned
with mark on cylinder head cover.
NOTE: Do not move camshaft or crankshaft once timing marks have been correctly positioned.
NOTE: Mark the direction of timing belt rotation (on the timing belt) for proper reinstallation.
INSPECTION
NOTE: Never forcefully twist, turn inside out or bend timing belt. Do not allow oil or grease to come in contact with timing belt.
3. Bend timing belt into a "U" shape as shown in figure. Distance "A" must be at least 1.0 inch (25 mm).
NOTE: Replace any component that shows damage, excessive wear, or that appears prone to a possible failure.
INSTALLATION
NOTE: Replace tensioner spring whenever timing belt is replaced.
4. Check that "I" mark on intake camshaft pulley is aligned with mark on cylinder head cover and "E" mark on exhaust camshaft pulley is aligned
NOTE: If existing timing belt is being reused, install belt in proper rotation direction marked prior to removal.
order.
NOTE: Do not add additional tension.
Tightening torque: 28 - 38 ft. lbs. (38 - 51 Nm, 3.9 - 5.2 kg-m)
10. Check that "I" mark on intake camshaft pulley and "E" mark on exhaust camshaft pulley are aligned with marks on cylinder head cover.
Deflection pressure: 22 lb. (98 N, 10 kg)
Deflection: 0.39 - 0.50 inch (11 - 13 mm)
Tightening torque: 5.8 - 8.0 ft. lbs. (7.9 - 10.7 Nm, 0.8 - 1.1 kg-m)
Tightening torque: 9.0 - 12.6 ft. lbs. (12.3 - 17.2 Nm, 1.3 - 1.8 kg-m)
16. install generator belt and adjust the tension.
Sep 17, 2009 | 2003 Kia Rio
How to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Aug 29, 2009 | Dryers
MANUAL FOR SIMPSON EZILOAD 5.5KG WASHING MACHINE TYPE NO R611364
I've seen one for $10 so if it's acceptable for you just let me know
Jul 22, 2009 | Washing Machines
Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Dryers Logo
279 people viewed this question
Top Dryers Experts
