Question about Archos 504 500870 Digital Media Player
Archos av500 wont power up or charge
Left my Archos connected to PC. Battery went flat (this model doesn't charge through USB) and despite hours hooked to the charger it will not power up or display any sign of life. The battery was getting a little short on stamina and would lose charge over a few days, even if unused.
I have tried removing the battery for a while, and held the off button down for over a minute. Also tried holding down off and tv/lcd buttons simultaneously, didn't work either.
Any ideas?
  • John Irizarry Oct 09, 2008
    I have a similar problem. My Archos 504 was sitting in its dock unused for several weeks. I plugged it into my computer via USB to transfer files to it. It booted up and recognized the USB connection then it abruptly shut down completely. I then tried unplugging the USB connection and turning on the unit. It was dead and did not boot. I tried removing the battery and holding the reset button down for 30 seconds. After putting the battery back I tried to turn it on again. It booted up and then shut down again.
    Even when I put it back in its docking station / charger it would not stay on.
    I am going to try to replace the battery and see if that fixes the problem.
SOURCE: playback button problems
please check what is your firmware version, the latest one is 1.6.23. If it is lower please upodate it by downloading the file from archos website. Maybe it would help
Posted on Jun 30, 2007
SOURCE: Archos not booting up - coming on
Kept trying the reset and just before I put a hammer through the hard drive it started again. Yippee!
Posted on Apr 05, 2008
Yazz226
  • 497 Answers
SOURCE: Archos av500 boot failure
its a HDD or OS failure
Posted on Jul 16, 2008
SOURCE: 504 recovery screen
hold the tv button slightly earlier than holding the power button, first tv then power (while still pressing the tv button). it should first boot up to a normal green ARCHOS screen, then it will enter the recovery mode.
Posted on Sep 08, 2008
SOURCE: Archos AV500 / USB harddive
the only thing that is keeping the drive from showing up is the format, the archos can only read fat32 external hard disks, so format the drive fat32 and you can use it
Posted on Oct 09, 2008
There is no sound or display on the screen when it is power on
The Apple iPod uses a rechargeable, lithium-based battery that can go between 10 and 36 hours between charges, depending on the model. You can charge your iPod using either an electrical outlet or your computer's USB port, but if you find that your iPod no longer takes or maintains a charge despite having the right connections, you should try some basic troubleshooting methods to restore the device's battery life.
Connect your iPod to a different USB port or wall outlet. If you use a USB port to charge your iPod, you may simply have a low-powered port, according to Apple. You can often resolve this by switching the cable to a different port, or using a wall charger (sold separately) to recharge instead. Charge your iPod for several hours. If you find your iPod completely unresponsive even as it charges, leave it plugged in for three or four hours and check again. If your battery life has been depleted completely, the iPod will need time before it can begin functioning again. Restart your iPod. A frozen or dysfunctional iPod may fail to charge, but a quick reset can fix basic functionality glitches. To reset a touch-wheel iPod, hold down the "Select" and "Menu" buttons until the gray Apple emblem appears on the screen. For iPod Touch, hold down the "Sleep" and "Home" buttons (the only two buttons on the device). Connect your iPod to your PC using the provided USB cable, open the iTunes software and click the "iPod" tab in the left column. Then click the "Update" button to search for and install the latest iPod software. Apple recommends keeping your software up-to-date to ensure that your battery life remains fully optimized. Purchase a new battery from Apple. If your battery fails to charge despite all your troubleshooting efforts, it may simply be too old and depleted to continue functioning. By taking advantage of Apple's iPod Out-of-Warranty Battery Replacement Program (see Link Below), you can send in your iPod and receive a replacement battery or replacement http://www.apple.com/support/ipod/service/battery/ iPod for a modest fee.
Feb 11, 2013 | Apple iPod Audio Players & Recorders
Archos Av500 startup problems
ull have to ask the company for a replacement if its under the warranty period
make sure to register ur device on the Archos website to get a 'Technical Support Passcode.'call Archos to tell them ur problem and if ur lucky they wud repair it free of charge
if u want to try it urself...i found this one of the forums on the net..
1.remove all the screws, and remove the battery.
2. Remove the hard disk from the player by disconnecting the ribbon connector carefully from the mainboard.
3. Try to startup the player after putting the battery back in place. This time, instead of turning off, the player showed a "cannot read hard disk" error with the option of formatting it. Made me realise that the hard disk was the culprit. However, I had heard the hard disk noises previously, and they sounded fine, so I realised it was a software issue (file system was corrupted)
4. Try to connect it back, same problem as before... Also it is very difficult to first start the player & then connect the hard disk, as the player is designed to shut off in that situation.
5. The best option after this would be to get a drive enclosure designed specifically for 1.8 hitachi hard disks to connect the disk directly to the computer using USB and format it.
6. However since I didn't have a specialised enclosure, I did a lot of trail and error with the player itself (running off mains while connecting the hard disk after starting the player without releasing the power button etc etc etc) which Im sure wasnt too kind on the hard disk, but voila, I managed to start it up fine WITH the hard disk in place without the player turning off using some weird combination of holding down the power button and connecting the ribbon on the bootup screen)
7. After this, he was able to select "format", and the player began working fine he lost all the data on the player itself, but luckily he had backups of everything!
Thanks for using Fixya
Jul 16, 2008 | Archos AV 500 400-Hours Video Recorder
First time charging up of archos 5,it has now been charging for about 14-15 hours. but the green light did'nt blink yet. it says after fully charge, the green light blinking. what can be the promlem about...
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Mar 11, 2010 | Archos Internet Media Tablet MP3 Player
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
from what i gathered with my archos 5 it is due to a power issue so the archos does not provide enough power to make the external hd work
Mar 08, 2009 | Archos 605 WiFi Digital Media Player
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
Archos 404 not charging
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
Apr 25, 2008 | Archos 404 Digital Media Player
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Jan 28, 2008 | Archos 504 500870 Digital Media Player
Copy Movie to my Archos Fault
Hi
I am from Portugal and i have the same problem in my Archos Av500.
Please, what can i do to resolve this problem ?
e-mail: cba_577@hotmail.com
Oct 24, 2007 | Archos AV 500 400-Hours Video Recorder
Archos 504 500870 Digital Media Player Logo
419 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
