Question about HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
If printer connected with my laptop & scan the Document & then message come "document page feeder error" & printout comes., & Same printer use on my desktop then document scan properly or Printout also comes please help me
scaner errror 6 for HP 3055
  • HP Master
  • 4,338 Answers
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 14, 2008
3055 glass
There is no need to change the mode. When the document is loaded on the document feeder, the screen displays "DOCUMENT LOADED" and shall copy or scan this document. To copy or scan from glass, DO NOT LOAD ANY DOCUMENT IN THE FEEDER. The printer will automatically copy / scan from glass.
May 10, 2013 | HP LaserJet 3055 All-In-One Printer
Hi, when I scan a document through the feeder in the top of my laser jet 3055 it creates individual pdf's for each page. I know it is possible to have one pdf for the entire document but not sure...
Yes, it is possible, all you need to do is one of two things:
One is use the feeder, that inherently knows multiple copies.
Or use the HP scanner software, (installed on each computer) and add a page.
One detail to watch is the size of the file. it gets quite large easily and certainly with multiple pages.....meaning you cannot e-mail the file sometimes...
Reset your output resolution for your document in the 100 to 150 range. Higher resolutions may be needed for some documents, but not most. This keeps the file size usable with a smaller file size.
May 11, 2011 | HP LaserJet 3055 All-In-One Printer
Hp 3050 scanning error message
Good day!Try to check the feeder if it has paper on it..then try on and off the printer until it holds normal status..
mastergani
Mar 29, 2010 | HP LaserJet 3050 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Paper in document feeder
there is no paper in document feeder
May 24, 2008 | HP LaserJet 3055 All-In-One Printer
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 Won't Scan
Dears
My hp 3055 is working fine on the network bt problem is "SCAN TO" Button is not being configured with the PCs.It displays all the PC names bt not able to scan. it diplays an error "Unable to Connect".
can any body help me out of this matter
Dec 27, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
257 people viewed this question
Ben Johnson
