Question about Nokia 6600
Charging problem my phone is not charging..... i thinkthere is something bad inside... i put good battery and a good charger but stilll it isnt charging..... can anyone helpme or share some points torepair this?
    President:
  • 1,952 Answers
Just check ur charging port connection...else change the port
Posted on Oct 02, 2008
I have tried mulitiple chargers, the charging port isnt loose.i took my phone batter out and put in my locker while i was at school ( 5 hours) but nothing happening
is the white tab on the battery turned pink??if so,you have water damage otherwise try a new 5 volt 2 amp charger and new battery,if nothing then your motherboard is bad.
May 15, 2015 | Alcatel T-Mobile ONETOUCH EVOLVE 3G...
Battery will not charge
There are only three likely solutions.
1. The charge port on your phone is broken (Most likely)
2. The battery has reached a thermal cutoff and will no longer accept a charge.
3. The charger cable is bad.
If you can try another battery or put that battery into another phone you can isolate that problem. If you can charge something else with your charger then your charger workers.
If that still doesn't work then plug the charger into your phone and lightly press on the charger. If your phone springs to life it means the charge port is likely suffering from a poor connection. If this is the case then sadly there is nothing you can do unless you're very good at soldering.
Jul 24, 2012 | Cell Phones
My blackberry torch isnt turning on. when i remover my batterry then put it back, the led light becomes red for like 3sec then nothng and the screen stay black! what can i do?? my blackberry is only 2...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 24, 2011 | RIM BlackBerry Torch Cell Phone
I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
Won't charge
if the charger is good, then there is something wrong with the charging port or the battery.
If the battery is very flat before you charge, the charger would not be unable to wake the battery because the battery cell is weak. Its only a desktop charger that can wake the battery cell.
So, test your phone with another good battery, and if it still does not charge, then the charging port is bad as I said earlier.
Best wishes.
Jan 12, 2010 | Samsung M220 Cell Phone
My razr will not hold a charge. Changed the battery,helped a little while but now it is doing the same thing.Dies constantly.
The charger is bad, not supplying enough current to bring the battery to full charge.
Or your replacement battery is bad.
There is a small possibility that the charging circuit inside the phone is bad.
So, before you spend money on a charger, see if someone will lend you their charger and let the phone charge over night. If it holds a charge then you know the charger is bad.
Good Luck!
Jan 03, 2010 | Motorola Mobility RAZR V3
Phone will not charge at all have charged battery in another phoneso not battery or charger phone is a nokia 6220 classic
Well, if you are saying that the phone is not charging the battery you put in it except you put the battery in another phone then will it charge,
1, Maybe you could check if the charger itself is bad.
2, Charger socket on the phone is faulty.
3, See if there is something like dust on the inside of the charging pot, then you forcefully blow breeze into it.
4, Finally, if non of these works, it means you need to go to a repairer to change the charging pot.
Sep 28, 2009 | Nokia 6220 classic Smartphone
Razr not charging -
New charger is needed - Razors are VERY particular about their type of charge - If it is a bad charger - You will see the battery indicator flashing red - and it will be empty - this is the phone saying pretty much that it cannot use this charger -
I have had ALOT of problems with razors and returned chargers - Try to scoop up an original - or take it to a location and test the charger first -
You can try to remove the battery and then put it back in - then try to charger it but i doubt that will work -
Get a new charger - TEST IT FIRST IN STORE!!!
Good Luck!
Jul 17, 2009 | Motorola Mobility RAZR V3
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
NOT CHARGING
Dear Customer,
try another battery of another 1100 model is stilll display that,
than try to do your battery in another model having same model,
its all about port for charging your battery.
so try all this steps will help you to fixed up,
THNX
May 18, 2008 | Nokia 1100
Nokia 6600 Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
