Question about JVC KD-S71R CD Player
CD Player is Malfunctioning
Unit has been working fine, however a couple of days ago, the CD ejected without playing. On re-inserting the CD, the unit shows 'CD Soft' then 'Play __' and then ejects the CD after a few seconds. The CD is being inserted the right way up. I wondered whether it has suffered from condensation internally, but the problem has remained. Should I try running a CD cleaner in the unit? Or should I reset the unit?
4 Suggested Answers
  • 5 Answers
SOURCE: MY UNIT WONT PLAY CD'S
there is obviously some problem w the disc reader, try resetting the radio and see what happens
Posted on Jun 28, 2009
  • 105 Answers
SOURCE: when i insert a cd inside the player after a few
cd is coming out means it is not loading properly or lens unit of the set is faulty.frist replace loading belt of cd see if it doesn't work clean the lens with shemoy leather. it should work.
Posted on Aug 07, 2009
  • 31 Answers
SOURCE: theirs power to the internal eject but not on
tie your ignition wire on your battery it should turn on if it works tie the ignition wire into the fuse pannel 10 amp if you have one
Posted on Jan 12, 2010
What does error code E-01 mean? CDs won't play and cannot eject trunk unit.
thats what i do with mine ,the phone thing but error E 1 means that a cd is jammed in the unit,happens to me all the time as i only use it for jaguar meetings .Now what you do is to pull out the cartridge and remove all the CDS then re insert it and press the eject button again and it might if your lucky retrive the cd in the player and return it to the cartridge ,.then refit all the others till it happens again
Apr 29, 2015 | Jaguar XJ8 Cars & Trucks
2007 toyota camry cd player reading error 1
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Jun 03, 2012 | 2007 Toyota Camry
My hyundai cd player ejects without playing. what do i do to fix that?
Your Audio Head Unit is malfunctioning... only solution - replace the radio/audio unit.
Jun 25, 2011 | Hyundai Motor 2004 Sonata
Trouble Ejecting CD. CD not playing
One thing have you tried to pull the CD out?
Dec 09, 2009 | 2001 Dodge Caravan
CDX keeps ejecting CDs some seconds after insertion
Replace the drive!!! I have six and this is the ONLY problem I see with these units!
Oct 08, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Error with Dual Head Unit
your lazor might be dirty or bad. try a disk cleaner.
Aug 19, 2009 | Car Audio & Video
CD player won't play CDs
Try getting a cd cleaning tool come with a disk with tiny brushes on it and cleaning solution to clean the eye or if you are using burned cds try and see what format you are buring such as mp3s mp4s some cd player only will play a certain formats such as mp3s.
May 07, 2009 | 1993 Saturn SL1
CD PLAYER FORD EXPLORER
I have an '03 Explorer with the 6 disc changer. It does the same thing. Many times, you can set the radio to "FM1" and hold down buttons 3 and 6 on the radio. This will put the unit into self diagnostic mode. After it runs the diag., turn off the ignition and remove the key for at least 30 seconds. Sometimes it takes a couple times but it always works on mine.
Oct 12, 2008 | Car Audio & Video
CD Ejects
A couple of suggestions. Check ALL the fuses, most units have 2 or more. Search the front panel carefully, many units have a tiny 'reset' switch, which is activated by pushing a pencil point into it's hole. They are usually marked, but with tiny letters.
Jul 17, 2007 | Eclipse CD2000 CD Player
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
JVC KD-S71R CD Player Logo
35 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
