Question about Radio Communications
MOTOROLA TWO WAY RADIO GP-63
I HAVE A MOTOROLA TWO WAY RADIO MODEL GP-63 WHICH I CANNOT VIEW THE EQUIVALENT FREQUENCY CAUSE ITS A CHANNELIZED. PLS HELP ME WITH THIS I HAVE NO MORE MANUAL ON SAID UNIT.
THE tPL and rPL is the same as the GP-68 when the tPL 205 and the rPL 023 for the kenwood brand.
    New Friend:
  • 109 Answers
Go to http://www.batlabs.com/gp68.html the manuals here should get you going. if not find someone with a frequency counter. this is alot easier than getting software for the radio.
Posted on Oct 10, 2008
Motorola gp 2000 how erase old frq how to set ham radio frq pls kindly send video message thank you
I do not know how to make a video. You need the software and proper cable to program a Motorola GP2000. Of course, a computer capable of running the software, which means Windows. Probably not windows 10 yet. I use Windows XP still. Then you need your Ham frequencies, which are easily obtained.
Jul 23, 2016 | Motorola Radio Communications
How to reprogram two way radio, its a motorola gp 339 and its set to 5 channels from when i brought it, can i reset it or reprogram it to normal uhf channels?
In order to reprogram this Motorola GP339 you need to have a programming software, radio interface box and programming cable for this radio then you can read and change frequency in it. To reprogram to UHF channels this radio must be in UHF band. Good luck!
radcom907
May 14, 2010 | Motorola GP300 Compatible 2 Way Radio...
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
Motorola gp 63
The GP-63 and the GP-68 uses the same users manual. You can download the user manual which also has programming and cloning information in it from:
http://www.batlabs.com/2way.html and choose GP-63......Good luck
Oct 23, 2008 | Radio Communications
Motorola gp 68
Batlabs at http://www.batlabs.com/2way.html (Hand Held Radios) has the GP-68 users guide(Operation Guide), on the right side I think what you might be asking is in "Basic Operation 2", if not look into the Programming section below it.
Tone squelch
Here is a link to download the user manual for the GP68 http://safemanuals.com/user-guide-instructions-owner-manual/MOTOROLA/GP68%20RADIO%20TRANSMITTER-_E
On your first radio, the one we've been discussing, I believe you have the DPL code set incorrectly. Your radio will go up to the number 126, but this is not the DPL code's number. It is simply a numbering system.
If I read the chart correctly:
DPL 205 equals the number 072.
DPL 023 equals the number 043.
Disclaimer: This numbering system listed in the user guide does not follow any common numbering system. I have other TPL/DPL charts which differ. The above reference is only based on what I have read in the user guide.
I am confident if your radio worked previously at another job site, using other frequencies/PL codes, that your only issue at this time is programming.
As for your unlock issue on the other GP68. Your radio may be in need of repair. The internal button is possibly wornout or has been depressed too far, and is bent on the board beyond the point of functioning.
Sep 25, 2008 | Motorola Radio Communications
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
AXU4100 Manual or help
On a Motorola AXU Series (including the 4100):
1. To unlock, press the “D” button for about a second or until the circle is gone. The circle with the line thru is the keyboard lock indicator;
2. To change channel, you need to press either the arrow left or right in Normal Mode;
3. To change PL (assigned to a channel), don’t think this can be done by the user
4. To change Ch. 1 from 464.500 MHz (PL-67.0) to 463.525 (PL-136.5), don’t think this can also be done by the user.
Even the built-in Programming Mode Parameters do not have this option to change assigned frequencies and PLs. An external programming software using a PC may or may not allow this.
These radios came pre-loaded with its channels assigned with specific frequencies/PLs. As used in a Motorola AXU411, they are:
Channel Frequency PL
1 464.500 67.0
2 464.500 77.0
3 464.500 88.5
4 464.500 179.9
5 464.500 None
6 464.550 67.0
7 464.550 82.5
8 464.550 94.8
9 464.550 179.9
10 464.550 None
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Dec 24, 2007 | Motorola AXU4100 (10 Channels) 2-Way Radio
Please Help me
MOTOROLA GP-2000 Programming Instructions
Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration
From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If the radio is turned on, turn it off. Press and hold the MON button and turn the radio on. A ringing tone will be heard,which indicates that the radio is in Programming mode. The PW and [] indicators are displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
Nov 06, 2007 | Radio Communications
Radio Communications Logo
237 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
