Regarding part # 239111
Does this part have to be desoldered and soldered into the main board. 1st time doing this stuff. also, since you have experience, if i buy a new main board, does it usually come with the flyback and everything on it? or do i have to buy piece by piece ? Thanks in advance for your reply.
  • 927 Answers
Good Day;
This a solder in part, you may want to consult a factory authorized service center, it's not for a novice. Good Luck, big IRISH.
Posted on Oct 03, 2008
Hi,i just change the main board because was thinking was the problem. (the tv was clicking turn blue and right away red and turn off....) Now the tv turn stay blue but clicking and nothing on the...
Sir when your tv does not operate when you open it and hear a clicking sound the most common part to be check is the power supply. When you remove the back cover of your tv be sure to unplug it then look for bulging capacitor, this bulging capacitor produces a low and unfiltered dc output voltage that causes your unit to malfunction.
If you see this bad capacitor replace it but observe the polarity, and also observe the solder part of the pcb of your power supply look for some loosed, cold solder or dry joints.
If you see this cold solder or loosed solder, resolder this but be sure not to connect separated pin if accidentally solder may cause much damage to the unit, you should have a soldering iron, soldering lead, desoldering pump. try to do this first before replacing the power supply board, power supply board is much expensive. Hope this help good day and best regards.
Sep 25, 2011 | Philips 47PFL7432D/37 TV
Works fine untill the kids stomp on the floor then it flickers and picture turns oval or even goes blank
Sir the problem of your tv is just a cold solder or loosed connection, try to tap the side of your unit it will react. If you are handy in electronics you can repair it by your self using a soldering iron, soldering lead and desoldering pump. If you remove the back cover of your unit be to unplug your tv to main ac outlet. then pull out the main board be careful when removing the main board some connectors may accidentally remove try to put some marking to the connectors. It is much better if you have a magnifying glass to easily identify the loosed or cold solder. When resoldering be sure not to connect separated pin if accidentally solder or joined together it may cause much problem to the unit. Or you can contact a service technician to do it for you and save you from stress good day and best regards.
Sep 12, 2011 | Hitachi 53UDX10B 53" Rear Projection...
The TV works great for some random length of time and then suddenly shuts off. If you leave it alone it will randomly come back on in an undetermined amount of time. Last night my daughter slapped the...
Sir the problem of your tv is only loosed or cold solder if you remove the back cover of your tv, try to observe the solder part of your tv, using a magnifying glass is much better to determine the cold solder or loosed connection in the main board. To solve this you should resolder the pin using a soldering iron, soldering lead and desoldering pump but be sure not to connect separated pin to avoid short circuit and cause much damage and harder to repair. before doing this you should unplug the unit. Or you can contact a service technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | Panasonic Televison & Video
Hiya there. i have a sony str-db 940 amp thats totaly dead i have checked all the internal fuses and the external one i have also checked the mains cable and everything is fine. i have completely...
hello, try testing the diodes first make sure you desolder 1 end and lift away from the board this will make sure you get a proper reading on the multimeter if theses ok check transistor next take them out of the board if ok then resistor same again out of the board . when testing capacitors make sure there not bulged it would be better if you can get an esr meter for testing capacitors good luck
regards
shaun
Dec 05, 2010 | Sony STR-DB940 Receiver
The picture just went off and the standby indicator is flashing. The self-diagnosis function is activated. We counted it flashed 6 times then went off for two seconds, then 6 times again./ /
This problems is the power supply board is the causes and the problems.Power supply board have dying parts call capacitors,these capacitors are alway bulges or puffing on it tops.U have tools like a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solder?Can u do basic soldering and understand basic electronic?Yes,searches the power supply board,that the board,where the power a/c cord plug into it.Replaced these dying capacitors that are bulges or puffing up on it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement,will solved this problems.
Nov 29, 2010 | Sony BRAVIA KDL32V5500 32 in. TV
How can chang sony tv stk ic
if it is a sony check to see if any of those little green resistors are blown first. most sonys have the stk chips on the main deflection board.they will be next to each other with a big heat sink on each.have a soldering and desoldering iron ready as well as tape and marker for the wires.. remove the wires from the board you dont have to take the board all the way out. start desoldering each pin. if some pins are stuck just touch the pin with the iron. clean the heat sinks.apply themal paste to the new ics. put the new ics through the holes and start soldering. this part can be tricky. put the tip on the pin the solder will flow just quickly remove the solder then the iron 36 times and your done.
Sep 11, 2010 | Hitachi 43FWX20B 43" Rear Projection...
JVC AV-48WP30 , how to change convergence
First of all tools,requirement to do the work on the Convergence board to do changes the 2 STK convergence ICS and some or all it resistors.U have a soldering iron,desoldering pump or soldering wicks and solders?Don't?must buy to do desoldering and soldering?Tries Amazon.com to buy solders.Tries wesites like Tvrepairworld.com to buy the convergence kit to replaced ur self,and buy the soldering iron here it have the desoldering pump attach to the sodering iron it self.For video tutoring how to take out convergence board out of the tv and replacing the 2 STK covergence ICS and some or all it resistors.Might included in the buying of the convergence kit,not,Try You Tube type in convergence problems,will have video some body doing it.
Jun 07, 2010 | JVC AV-48WP30 48" Rear Projection...
The blue is to strong on the tv everyone looks like a smurf.
Could be bad connections (oxydized or desoldered pins) at the picture tube neck or on the main board (you would need to resolder and/or clean the contact pins), possibly a problem with the colour decoder or related components (bad soldering, faulty components).
You can find more details at:
http://www.repairfaq.org/sam/tvfaq.htm#tvoctwts
Regards,
Triarcuate
Oct 18, 2009 | Samsung DLP HL-P5663W 56" TV
Fuji z10fd no power after lcd replaced
I have repaired several of these. On most of them I found that one or both nano fuses on the main board have gone bad. They are labeled F2 and F3, they are 2 amp nano fuses. They are located on the back side of the main circuit board, near the top. Right at the top of the SD card socket. You will need to use a soldering iron, and desolder both Battery contacts. Also several wires on the main board will need to be desoldered, to get to the fuses. You should have some experience working with surface mount components and soldering before attempting the repair.
Feb 22, 2009 | Fuji FinePix Z10fd Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
