Question about JVC MX-D302T Shelf System
CD OPTION NOT WORK
CD portion does not
work at all. The trays will not eject
  • njartiste May 11, 2010
    How do I check the belts / gears myself??  I can see a bar inside moving up and down as if it is looking for something.  It just clicks and clicks.
    Problem Solver:
  • 6 Answers
You may need to check the belt or gears that open the tray i have had a simular problem with a few concoles and cd plaers my self
if u can not acces the tray ejection mechanisum u may need to take it to an electrical repair shop
Posted on Oct 02, 2008
Epic 1314 notebook how to open CD tray or does it have a CD/ROM at all
Hi
this model has cd tray
and to open in has 2 ways
1st go to my computer and select the cd rom drive and select the drive then right click on that drive ,select option eject
the tray would be ejected
2nd you will see a small hole next to the button of cd tray just put a small pin inside the hole you will listen a click sound and the tray would be ejected
Aug 15, 2016 | Computers & Internet
What is the proper procedure for opening the dvd drawer on a gateway ne 522 laptop
Locking device or software installed First, verify no locking software is being loaded that prevents the tray from opening. If you are unable to determine this, reboot the computer and as it is booting up, eject the tray. If the tray is able to eject as it is booting, but stops working after loading Windows or your operating system something is being loaded that is preventing the drive tray from opening. This is most commonly software such as a CD burner program that has taken control of the drive.
Bad eject button If you are running Microsoft Windows open My computer, right-click on the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective and it is recommended that the drive be replaced.
Jan 06, 2014 | HP Computers & Internet
My dvd tray is not ejecting,i cannot insert a cd
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 05, 2013 | Computers & Internet
The CD rom does not open?
Take a paper clip now straighten it push it in the tiny hole on the front of the CD ROM drive
the drive should open
Apr 12, 2011 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Ejecting a Stuck CD in Mac OSX
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 17, 2010 | Apple iMac G4 Desktop
I need to remove a disk from a Sony NEC Optiarc AD-7640S
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Dec 23, 2009 | Computers & Internet
The drawer that holds the cd's will not open. Where the cd screen is it changes to def.
Most DVD players come with an emergency eject option. First turn the player of for a while and then try ejecting again. If it still doesn't eject press and hold the eject button for 5-10 seconds. This will force the eject motor for about 5 seconds. If everything fails your Player's CD tray assembly (could be a faulty motor or the plastic support on which the tray slides is worn out). You will need to get the tray assembly replaced.
Let me know if you need more help.
Sai.
Dec 16, 2009 | Audio Players & Recorders
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
My cd is stuck in macbook and is not being read by my computer it only makes a funny sound when i reload it
A CD or DVD disc can become stuck in your Macintosh. It may not be appearing on your desktop or could be causing the computer to lock up if the computer cannot recognize it properly.
[edit] Solutions
Sep 30, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
JVC MX-D302T Shelf System Logo
101 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
