RCA P52923 Wont turn on
Hi there.
Got a question. RCA P52923 195K3B RCA tv that wont turn on. All I hear is a clicking noise like its trying to boot on but wont. I had a tv guy come to my house and told me its a power board but I highly doubt that. I am not a tv repair woman, but I work on laptops...Close enough. ha! Could you help? I see problems with this tv in power supplies and resistors but no power boards. The tv worked fine for many years, went on vacation for 2 months, the whole area was shut down because of a fire so they shut down the electricity. Guessing in this time, the tv blew out. However, like I said it turns on, but no sound and no image just clicking. Any ideas? Any would be good,thanks
  • sookar24 Oct 02, 2008
    nevermind. i figured out its the flyback.
SOURCE: House Fire caused by SONY kp61xbr48 T.V.
Buy a JVC tv. They recalled their tv's that are like the kp61xbr48 for 2 reports of smoke and charing.Sony must be trying to hide something or what??? Maybee a little too hot!!??Was their a cooling system or fan in the tv??????
Posted on Jul 25, 2006
SOURCE: tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Posted on Sep 27, 2006
Slinteriors
  • 8617 Answers
SOURCE: Sony KP-51WS500 wil not turn on
did you notice any color flashing at all during the poping? As that model is fairly famous for the green CRT shorting out or the flyback arcing. Does the power LED light up at all or possibly blink? Let me know about the LED and I will try to help you diagnose what the problem may actually be. respond to this same post, so I can keep this problem seperate as I have so many responses with different problems that its hard to keep them straight unless we keep using the origional request each time.
Posted on Jun 19, 2008
  • 4 Answers
SOURCE: Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Posted on Aug 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: HD52W59 Convergence Power Supply
you can get the replacement ITC222 convergence power supply board at the following link. They have one at promotional sale price this week also under the sale items category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
Wont turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 22, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Turn off itself and wont turn on. There is a noise, when you plug in. Click, click
Your description indicates that the power supply has failed; the noise you are hearing is probably caused by a relay that is interrupting the AC supply to avoid damaging the supply any further or causing a fire.
Disconnect your set from the wall and allow several hours (overnight is better) so that dangerous voltages have a chance to discharge.  You will have to gain access to the lower section of your system to look for a separate board with larger components on it, some cylindrical (capacitors), some block-like (chokes and transformers). If you can locate this board, it should be user replaceable.
The next step would be to look for unique markings on that board looking like an assembly number. With that in hand and the model number of your set, look for the RCA service center in your area and call them to determine whether they have a repair or replacement assembly.
If only a replacement is available, keep the failed unit for possible repair in the future when the new one fails since mfrs. will not have entire assemblies available in a few years.
May 19, 2009 | RCA HD52W58 52" TV
Tv wont turn on
it sounds to me a transformer in your set has gone hard to say witch. im guessing it is a CRT set the best thing i could suggest would be to take it to your local tv repair shop they should be able to sort this for you and it shouldn't be to expensive.
Mar 10, 2009 | RCA 27V514T 27" TV
MY TV IS CLICKING AND WON'T TURN ON
Good Day;
The most common problem with these Models/ Chassis' is IHVT (intergrated high voltage transformer) going bad. They have around 99% failure rate. T14401 > part number > 239111 >IHVT.
Try to get RCA part a little more pricey but more reliable then after market ones. You can tell if it's bad by the crust on the top of IHVT.
Good Luck, big IRISH.
Sep 11, 2008 | RCA P52926 52" Rear Projection Television
RCA 36695BC wont turn on
I'm afraid this failure is not just a fuse failure in your TV since you still can hear the relay clicking. This fix might not be a DIY.
Where can I send you additional info on what could be wrong with your TV?
Jul 24, 2008 | RCA F36695BC 36" TV
RCA Projection TV Model P52923
Good Day, Ajejo;
Sorry I'm not Circuit City, but work for them for many years down here in TX.
The chassis number is the best way to find out information about the TV. The CTC195K3 is very commonly known to have bad 'flyback'. The crusting you indicated on top of said transformer is the indication that it is defective, I've changed 80-90 of them over the years.
So, job well done, your wife must be proud of you.
Part information: Location; T14401, Part Number; 239111, Name; IHVT, Integrated High Voltage Transformer.
Caution when replacing the fly, looking at the bottom, the pins are shaped like a horse shoe. At the closed end there is an separate pin. Make sure new has the extra pin (for focus), Iv'e had many lately that does not have it.
Good Luck, big IRISH. PS; good job good eye let me know.
Jul 11, 2008 | RCA P52926 52" Rear Projection Television
Tv wont turn on
The green light indicates that it is getting power from the outlet ok.
The clicking is the power relay trying to turn it on but there is an internal fault forcing it to shutdown. You either have a power supply problem, horizontal output transistor (HOT) is shorted or a bad flyback transformer. In any case it can most likely be repaired by a qualified technitian. If it is the flyback it may be expensive.
Mar 10, 2008 | RCA F32650 32" TV
Televison & Video Logo
Top Televison & Video Experts
