Question about Yamaha RX-V659 Receiver
Playstation 3 Can I hook up my PS3 to this amp - if so which port do I use - the PS3 is currently linked to my High Def TV, but without the amplifier I can't use the surround sound function.
  • 165 Answers
Hello of course take the outputs from your ps3 go video input in amplifier now from the amplifier connect the outputs right and left and video to tv.................all of this is made by rca connectors. saludos
Posted on Nov 24, 2008
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
Everything is connected but when i turn on the ps3 the tv says unsupported signal check your device output
make sure your hook-ups are connected correctly and if so could be a high def setting or componet setting inside you system.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
It works fine with a high def cable, but when i go to connect it to a tv with the audio video cords nothing at all will come up on the screen.
There are certain settings on the PS3 that has to be changed each time that you switch from High Def to AV. You have to plug both cords in and turn the PS3 on and view the screen with the High Def. You have to go to Settings --> Display Settings --> Video Output Settings
then follow the instructions.
Watch this video and it will help you switch from High Def to AV.
http://www.youtube.com/watch?v=TBqfeIpKm70&feature=related
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
How do you audio output to a stereo amp
if your amp has a optic cable slot u may need one of these to transmit sound from ps3 to amp :)
May 17, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 not working with older model Pioneer AV receiver
If you have set the component output on the ps3 for high def,ie 720p or 1080i and do not get a picture it sounds like the component input is not high def enabled on your amp,change the setting on ps3 to standard 576 output,or put picture into tv then sound into amp if you want to run 720p or 1080i.
Hope this helps.
CABLE GUY.
Jan 01, 2009 | Audio Players & Recorders
PS3
I never tried a Ps3 on a standard def tv before but you may need a HDMI cable to connect from the tv to the console and you need a port on the tv for the av cable that comes with the ps3 to plug into the tv from the ps3. An HD tv has everything for the ps3 to run
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
P3 not playing high def dvd
make sure your tv input is on the right selection
Dec 10, 2007 | Sony PlayStation® 3 (60 GB) Console
Playstation 3 display is in black and white
when u swith the swith console off  plug it in too the standard def tv but hold the O/1 button for 10 seconds then u will see a nice and shiny ps3 working on ur standard def tv
i had the same problem
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Unhooked ps3 from an hd tv and plugged it into an sd tv and it shows no picture.
when in standby mode(redlight) push and hold the power power button until you hear the second beep. This should reset your PS3 to it's standard 480i resolution.
Sep 21, 2007 | Sony Playstation 3 (PS3) Console
Open Questions:
See all Yamaha RX-V659 Receiver Questions
Yamaha RX-V659 Receiver Logo
97 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
