Last week I took out a bad, old CD-RW drive and put a new one in. Works great!
Bad news is my DVD drive was working fine before this new CD-RW install. DVD will play through DVD Media Player Classic but not with RealPlayer or Windows Media. DVD's used to play just fine with other players, but now... only Media Player Classic.
Sounds like a drive issue, but why would my DVD drivers be changed when I didnt mess with the DVD drive?
-   I have combo driver, which can read cd's and dvd's but now a days it is not able to write cd's and cd-rw. Please help me.-   amithdfc
Solution #1
posted on May 30, 2006
man1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Check the jumper settings :)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 19, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Re-install the programs that aren't working correctly. The only way i know to explain is to say that they are installed to work with the old drive and not the new???
If the Drives are sharing the same cable and are IDE or ATA Drives then one needs to be set to Master and the other to Slave This is the Jumper settings options... maybe your Registry settings are affected by the drive change and someone with good technical knowledge of Registry needs to look there and establish why the programs have lost the Older drive...
i bought a pyro audio creater but the turntable black belt was off so the turntable is not spinning...
(More)
i bought a pyro audio creater but the turntable black belt was off so the turntable is not spinning .what is the correct position for this belt?
Using Windows 7 Ultimate, I Tried burning 2 DVDs, both reported DVD Burning Failure Errors. Device...
(More)
Using Windows 7 Ultimate, I Tried burning 2 DVDs, both reported DVD Burning Failure Errors. Device infor reports drivers up to date and device working properly. No error codes to troubleshoot with!
Hi when I try tto burn a dvd using nero6 it stops chucks the disk out and says power cabliration...
(More)
Hi when I try tto burn a dvd using nero6 it stops chucks the disk out and says power cabliration error and burner is dirty what can I do to solve this problem
I was upgrading its firmware when suddenly my pc stopped responding and restarted. It was a bad...
(More)
I was upgrading its firmware when suddenly my pc stopped responding and restarted. It was a bad flashing of the CDRW's ROM chip. Anyways to re-flash it?
