Question about Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB HD WITH HUGE 15" TFT SCREEN (GAT93400) PC Notebook
Display drive I seem to have lost or deleted my Display drive. All the icon, the screen is very large. I can't seem to locate the right drive. I think I may have deleted a drive??? Not sure.
How do you delete photos/videos?
iPhone:
launch the Photos app, navigate to the Photos tab on the left until you get to Moments view. Then tap Select at the top-right of the screen, and tap each Select link next to each batch of images you want to delete. Tap the Trash button in the bottom-right corner, confirm that you want to remove the images, and they'll be deleted.
IDGYou can also delete images in batches from the iPhone's Moments screen."But hang on a second!" you might be murmuring in an exclamatory way, "I just launched the Photos app on my phone and there are still pictures there. What's up with that!?"
Ah, that would be your Photo Stream.
"And those photos are still taking up space on my iPhone, right?"
Well. Yes.
"And so we haven't really gotten rid of all the photos on my iPhone, have we?"
No. No we haven't.
"Sooo..."
Sooo you need to switch off Photo Stream on your iPhone. To do that go to Settings > Photos & Camera. In the resulting screen flick the My Photo Stream switch to Off. This will cause the pictures to disappear from your phone.
Android:
Delete Single Photo
  1. Open the "Gallery" or "Photos" app.
  2. Open the album that contains the photo you wish to remove.
  3. Tap and hold the photo until a trash icon appears at the upper-right portion of the screen.
  4. Tap the "Trash" icon located at the upper-right portion of the screen.
  5. Confirm your selection by tapping "OK" (Gallery) or "Move to Trash" (Photos) and the photo is deleted.
Delete Multiple Photos
  2. Open the album that contains the photos you wish to remove.
  3. Tap the "Menu" icon located at the upper-right corner of the screen.
  4. Choose "Select item" (Gallery) or "Select..." (Photos).
  5. Tap the photos you wish to remove. They will become highlighted.
  6. Tap the "Trash" icon located at the upper-right corner of the screen.
  7. Confirm your selection by tapping "OK" (Gallery) or "Move to Trash" (Photos) and the photo is deleted.
Delete Entire Album
  1. Open the "File Manager" app.
  2. Navigate to the location where the photo album is located. You can usually find them in the "DCIM" or "Pictures" folder.
  3. Tap and hold the folder you wish to remove.
  4. Select "Delete".
Aug 06, 2017 | Cell Phones
Lost all contacts on iPad mini
If the important contacts in iPad get deleted, you will try to get them back. Restoring iPad with the iTunes backup is the easiest way to recover deleted contacts on iPad mini. If you update your iPhone backups regularly, then you can recover most of the important data from the backup. The restoring process is also easy to be done, and the following tutorial is for the new users of iOS devices:
  1. Connect iPad mini to computer with USB cable, and iTunes will launch automatically. If not, you should manually start iTunes.
  2. iTunes will recognize iPhone and display the iPad icon at the upper left corner. Click the iPad icon.
  3. The control panel of iPhone appears after you click the iPad icon. Click Summary in the panel.
  4. Click Restore Backup in the right part of the window. Then iTunes will allow you to choose the iPad backup, and finish the restore.
Visit here to know more methods about iPad contact recovery.
http://www.leawo.org/tutorial/how-to-recover-deleted-contacts-on-iphone-6.html
Nov 11, 2015 | Apple iPad Mini
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
Page seems to be too wide for monitor screen. when centering up down & sideways either I lose some on the left or right of screen or a little on both sides. How can I shrink display Now I have only art...
It sounds like the resolution on your machine is set too large for the screen. Right click somewhere on your desktop where there is no icon. Assuming you are using Windows 7, there should be a Screen Resolution option in the little menu that appears - click on that, then try changing the resolution to 1366x768, which may even say Recommended next to it in brackets. If that still doesn't seem right, try some of the others, until you are happy with the display.
Hope this helps.
Jul 25, 2011 | Compaq Presario CQ56110US Laptop
How do I change the font or Text sizen
  1. Go into your Control Panel by first clicking on the Start Button.
  2. Then click on the Control Panel icon located in the right column of the Start Menu.
  3. If your Start Menu is set to the CLASSIC VIEW then begin by clicking on the Start Button.
  4. Then click on Settings, then click on the Control Panel icon to open up the Control Panel.
  5. Now, Double click on the Display icon to open up the Display Properties Window.
  6. Then click on the Appearance tab at the top of the screen.
  7. At the bottom left side of the screen you will see an area to change the Font Size:
  8. Use your mouse to switch between normal, large and extra large according to your preference.
  9. Then click on the OK button to save your changes and exit Display Properties window.
  10. Windows XP will immediately adjust to your new Font Size without restarting your system.
  11. Then close the Control Panel to return back to your Windows Session.
Jun 10, 2011 | Computers & Internet
Increase my font size
You did not specify your operating system.
For Windows XP
If your Start Menu is set to the Classic View, then begin by clicking on the Start Button.
Apr 26, 2011 | Computers & Internet
The icon display is taking up too much of my screen and I would like to reduce it.I can't seem to find the file that has that feature. I have done it before but can't remember how.
Hello amionalden, to make the [Icons] smaller; do the following. From the "Desktop Screen" paul7of9_74.jpg (Right) click on the "screen," there will be a 'list' of items, choose the "View." when you point to it a 'side window' with the [Arrow] will open. There will be another 'list' example: Large Icons, Medium Icons... Choose the {Medium Icons}, this will make them 'smaller.' "I hope this information is helpful? Thanks for using FixYa, paul7of9."
Feb 07, 2011 | Dell Inspiron B130 Notebook
The screen moves from small to large and I don't
Its the "Zoom" Control located I think on the lower right of the screen; increase the size of the display to 100 %
Aug 12, 2009 | Acer Aspire One PC Notebook
No composite input signal
Try the following:
Right after power on, tap the F8 key to see if you can get a short menu to come up.
If it does, select "Safe Mode."
If your screen looks different, it may be just the driver for the display card or monitor is trashed (Windows like doing that, keeps us challenged).
- Open Control Panel, then System, then Hardware, finally Device Manager.
- Locate Display adaptors, open and delete the adaptor listed (all, if more than one.)     - Locate Monitors, open, delete any listing there.
Reboot.
Windows should 'find' two 'new' devices and install the drivers for them.
The display may still be different if you had other than the default settings.
Go then to the Display folder of the Control Panel, click on 'Settings' and experiment. Depending on your Windows version, if you choose something dumb so it makes the screen unreadable, ignore it and Win will ask if you want to keep it and give you some time to acknowledge that you like it. When you don't, it will just go back to the pre-tinkering settings.
Apr 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Desktop icons lost
Sadly, there is no straightforward command you can use to recover them, but well, there are three ways, really, that you can get your icons back, depending on which ones were lost, that you are referring to. for this, I'm assuming you're running a more recent version of Windows.
----- For Windows XP ------
1) for recently deleted icons- check your Recycle bin, they could still be there.
2)for system-installed icons, such as My Computer, and Internet Explorer- you can recover these by going into your Display Properties (Start -> Control Panel -> Display). Select the Desktop tab, and click on Customize Desktop. Make sure the "General" tab is selected, then, under the "Desktop icons" section, tick off the icons you want to restore. click on "Ok" when you're finished, and Presto! those icons are up on your screen.
3)If the above two options don't work, you may have to add them manually ( a pain, I know). To add a shortcut in this fashion, right-click anywhere on the desktop, and select New -> Shortcut. you will have another window appear on your screen, asking you where the file you are making a shortcut to is located, and what you want to call it. follow the steps, and when you're finished, you should have a working icon. (another option would be to reinstall the software that made the icons, but that's also a pain in itself.).
----for windows vista ----
1) check the Recycle Bin (same procedure as Windows Xp, although, if your recycle bin option is deleted, then you have a problem that can be solved by using #2)
2) For system-installed shortcuts- follow This excellent tutorial.
3)Manually installing shortcuts- same as for XP.
Dec 17, 2007 | Computers & Internet
Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB HD WITH HUGE 15" TFT SCREEN (GAT93400) PC Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
