I need a wiring diagram for my Hoover 200M 4.5Kg washing machine
  • Anonymous Oct 02, 2008
    When I opened the timer panel, few wires from the timer came off and I do not know which wire is to fix at which number. Pls help me.
  • PipNz Nov 09, 2008
    I need a wiring diagram for a Hoover 201M 5 kg washer.
    Two of the suspension struts wore out, which was easy to fix, but in the course of opening the console, several electrical connectors got unplugged. I don't know which to plug in where, but all points are numbered.
  • 150 Answers
SOURCE: Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Posted on May 08, 2008
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
Posted on Mar 15, 2009
SOURCE: Need wiring schematics for Hoover 750L washing
www.washerhelp.co.uk/diy-repair-help_4.html
www.washerhelp.co.uk/diy-repair-help_3.html
These sites above will help; Yo get a Schematic, you need a service manual, I was unable to find one for your model.
http://appliancejunk.com/forums/index.php?topic=2846.0
This link above, has "Generic" manuals, download one of them, you will find a schematic diagram, of a generic, circuit, they are all pretty much the same, in the add on's to the "Control Board" It will be helpful in tracking any faults, also inside the manual is troubleshooting tips, that apply to ALL, they will help you narrow it down.
Always check, hoses, pump, filters.
might be your drain pipe is too far down the drain tube, take out your pump and clean it.
Check the pump the spade connections , might be a bit loose.
This COULD be a clutch problem. Pads sound like they are gone. If its over 5 years old it will be better to replace. And throw-out bearing in a washer? there is tub and clutch shaft bearings; but it takes quite a bit of experience and tools to change.
good luck and consider shopping around. It is always best to get an Engineer.
Posted on Apr 11, 2010
SOURCE: do you have a wiring
http://www.washerhelp.co.uk/diy-repair-safety.html
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Above is a generic washer although the wiring won't be exact, it still will be relevant, and eminently transposable to this make. If you simply perform the troubleshooting procedures no doubt you would be able to isolate and hopefully repair your problem
http://service.hoover.co.uk/manuals/pdfs/VHD8122.pdf
Hope this is helpful, i could find little on your exact modle.
Posted on May 13, 2010
SOURCE: Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Posted on Jul 13, 2010
Problem Hoover 200m 4.5kg top loading Machine not drain water
no drain? do u have a spin cycle working? If so check the water pump and hoses for clogged blockage. or broken obstructed propeller, can u turn it (pump) by hand?
Mar 02, 2015 | Hoover Washing Machines
I HAVE SOMETHING STUCK BEHIND DRUM IN HOOVER 200M WASHING MACHINE HOW DO I FIX
Hi, I am having the same problem atm and was wondering if you fixed it?
Where there any damages to the machine and how much did it cost to repair if you called a repair man?
Thank you
Claire
Nov 20, 2010 | Hoover Washing Machines
Does the hoover 200m 4.4kg top loading washing machine have a lint filter if so where is it
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
Jun 17, 2010 | Hoover HTC243 Top Load Washer
Hoover 200m 4.5kg washing machine will not use cold water to wash. How do I switch it to cold water wash?
You can fix one of two ways.
1/ replace the cold water solenoid valve
This is located directly behind the cold water hose fitting
at the top of the machine
Remove the small electrical control panel by removing the
three small screws.
2/ If you only need the cold wash program you can save
money by swapping the vaves around. They are easy to
remove and they are held in place by a plastic insert which
lifts up to remove them .
Make absolutely sure that your Machine is disconnected from the mains supply before you replace these valves
Regards
Bill K
Tuart Hill
WA
Apr 11, 2010 | Hoover HTC243 Top Load Washer
Hoover 200m Top Loading Machine Spin Cycle Too short
no not normal many different things can be wrong need more info
May 08, 2008 | Hoover HTC243 Top Load Washer
Hoover washing machine 200m, making the worst sound ever...
never continue to use a machine that makes any noise it shouldn't you can only make matters worse and could do severe damage that can't be repaired, sound like something in the drum or something loose outside the drum, like suspension etc based on the info given i would just say ask an engineer to have a quick listen, many do a free estimate
Oct 05, 2007 | Hoover HTC243 Top Load Washer
Sep 18, 2007 | Washing Machines
Problem with Hoover 200M
Hi All
The solution is a faulty solenoid valve, either the hot or cold valve depending what temperature you are using.
Replacing the valve is easy turnoff machine unscrew hose, remove 3 srcews to lift control cover, slide out locking tab, unclip wires the replace valve which cost about 30-$40
Tobor
Aug 22, 2007 | Hoover HTC243 Top Load Washer
Dec 09, 2006 | Hoover HTC243 Top Load Washer
Washing Machines Logo
541 people viewed this question
Top Washing Machines Experts
