Question about Gateway 6520GZ Notebook
Touchpad not working
The touchpad is not working/cursor won't move- can not get a response from any amount of pressure, tap, drag, etc. The cursor if stuck in the middle of screen. Tried restarting several times and am unable to download from Synaptics.com without errors interrupting. The touchpad feels warm/near hot to the touch also. Everything else appears to be normal.
The warranty is long expired. Gateway online tech told me to do a recovery but that seems a bit extreme for a stuck cursor.
Should I recover? Is the touchpad something I can replace (myself) or is that necessary at all? Is there anything I can do? :(
P.S. I'm not very computer savvy, so the simpler the explanation, fix or whatever- the better :)
  • Gateway Master
  • 787 Answers
If you are not computer savvy I do not recommend you trying to replace the touchpad, it usually involves completely disassembling the notebook.
Simpliest solution - plug in a usb mouse.
Posted on Oct 02, 2008
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Milk was spilled on the touchpad of my laptop the cursor moves but it won't click
You need to replace the touch pad or you can connect an USB mouse to your laptop and not use the touch pad.
Mar 21, 2013 | Dell Inspiron Computers & Internet
Panasonic CF-52 touchpad will move but not select
You're going to have to download the device driver for the tap gesture to work correctly :O You can find that on the manufacture's website under support and drivers.
Feb 24, 2013 | Panasonic Toughbook 52 Notebook...
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
Dell studio 17 laptop
When you tap your touchpad it acts the same as a left-click action. accidentally skimming the touchpad when typing can be interpreted as clicking your cursor. If your cursor was over a different window than the one you were typing in, then you may have accidentally clicked out of the window where you were typing.
When typing try to place the cursor past the very end of your text and then if you accidentally bump the touchpad it won't mess up your work.
please rate my response!
Jul 11, 2010 | Dell Studio 17 Laptop
How do you highlight with a touchpad
With most touchpads you hold down the left mouse button to select then move the cursor with the other hand by pressing a finger on the touchpad and dragging it. Be sure your touch pad is not disabled - usually a button near it with an indicator LED.
Dec 12, 2009 | Toshiba Satellite A505-S6970 Notebook
The left click button on my samsung r510 is not working, can you help me please?
Use "tapping" to do the left click if the button isn't working. You can click, double click and drag things around using just the touch panel.
Position the cursor on the icon you want to select and do a quick "tap" on the touch panel, the icon will become selected, equivalent to one click. To double click, double tap. To drag things around, do a tap and quickly tap again without lifting your finger and move.
It takes a little practice but you'll get used to it. Also the touchpad software has some settings that will let to configure the sensitivity and time between taps among other things to adjust the movement to your preferences.
Oct 28, 2009 | Samsung R610-64G Laptop
Touchpad click is not working...I checked the
I use to work at Circuit City...this is a manufactoer problem. Contact Acer (http://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx) that link will ask for your s/n and should give you a number to call the support and have them send the unit in. Im sorry this happend to you but Acer knows about this prob and hopefully will ship you a new mouse...at which ask on here and I would love to help you replace the mouse.
Oct 21, 2009 | Acer Aspire 5610-4648 Notebook
Acer Keyboard Cursor moves without my knowledge
Someone has remote assistance to your computer. Go into Control panal and turn "Remote Assistance" off
Apr 14, 2009 | Acer Aspire 5920-6423 Notebook
Laptop Touchpad - cursor random dragging problem
On my acer all I have to do is press function F7, Function is the button with 'Fn' on it. I am not sure if that works for HP, but its worth a try. Also, is there a switch near the touchpad? Sometimes there is one that switches the touch pad on and off. You can also try other Fn(function) F1 or Fn F2 etc. and see if one of the other "f" buttons work.  I hope this helps, let me know how you made out. Good Luck!
Jan 16, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Gateway 6520GZ Notebook Logo
651 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
